[gdal-dev] [OSGeo/gdal] Add GDT_Int8 support (RFC 87) (PR #6633)
Sean Gillies sean.gillies at gmail.com
Tue Nov 8 16:08:36 PST 2022
Even,
Argh, I typed "unsigned char" when I meant "signed". Changing GDT_Byte to
*signed char* is too big of a change, I guess?
I like the plan for PIXELTYPE.
Sorry about the noise, everybody!
On Tue, Nov 8, 2022 at 5:04 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Sean,
> Changing GDT_Byte to unsigned char is too big of a change, I guess? I can
> work with that.
> GDT_Byte semantic is already unsigned char / uint8. What did you mean?
> Is there any advantage to a GDT_UInt8 type that can't be changed by a
> PIXELTYPE option?
> That would be super confusing if we had both GDT_Byte and GDT_UInt8 and
> they are not just simple aliases.
> The PIXELTYPE option should die. The RFC proposes to make it die on the
> reading side (as a metadata item).
> We could also make it die on the writing side as a creation option, but I
> didn't dare to do it right now and just propose this is considered a legacy
> deprecated way. Would certainly be something worth doing for a GDAL 4.0 if
> such thing ever happened.
> On Tue, Nov 8, 2022 at 12:39 PM Even Rouault <notifications at github.com>
> wrote:
>> Ubyte (same as uint8) vs byte?
>> what do you suggest exactly: keep GDT_Byte in the enumeration and add #define
>> GDT_UByte GDT_Byte to create the alias ?
>>>> Reply to this email directly, view it on GitHub
>> <https://github.com/OSGeo/gdal/pull/6633#issuecomment-1307736762>, or
>> unsubscribe
>> <https://github.com/notifications/unsubscribe-auth/AAAIHIKG7X65SX4OULJMUFTWHKT5TANCNFSM6AAAAAAR2E6MJY>
>> You are receiving this because you commented.Message ID:
>> <OSGeo/gdal/pull/6633/c1307736762 at github.com>
> Sean Gillies
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221108/2615aa73/attachment.htm>
