[gdal-dev] gdal2tiles: RuntimeError: Cannot find coordinate operations from `ENGCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere"
Terra Frost terrafrost at gmail.com
Wed Nov 9 14:13:15 PST 2022
I installed the GDAL suite of tools by doing the following:
sudo add-apt-repository ppa:ubuntugis/ppa
sudo apt-get update
sudo apt-get install gdal-bin
sudo apt-get install libgdal-dev
I'm running Ubuntu 20.04 and when I do gdal2tiles --version I get "GDAL
3.4.3, released 2022/04/22"
On Wed, Nov 9, 2022 at 11:01 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Terra,
> you didn't specify how you got GDAL and PROJ, and which versions of those
> you use.
> Make sure to solve the "proj_create_from_database: Cannot find proj.db"
> error. Check if the PROJ_LIB environment is set and if it points to the
> directory where proj.db is placed
> The "free(): invalid pointer" error could also suggest that you have
> several PROJ versions that are linked at runtime by GDAL.
> Even
> Le 09/11/2022 à 17:54, Terra Frost a écrit :
> I have two TIFs that I'm able to run gdal2tiles on without issue,
> however, when I do gdal_merge I am unable to do gdal2tiles on the result.
> When I did gdal_merge on the two TIFs I got this warning:
> Warning 1: PROJ: proj_create_from_database: Cannot find proj.db
> Warning 1: The definition of projected CRS EPSG:3857 got from GeoTIFF keys
> is not the same as the one from the EPSG registry, which may cause issues
> during reprojection operations. Set GTIFF_SRS_SOURCE configuration option
> to EPSG to use official parameters (overriding the ones from GeoTIFF keys),
> or to GEOKEYS to use custom values from GeoTIFF keys and drop the EPSG code.
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> Despite the warning the two TIFs merged without issue, however, when I try
> to run gdal2tiles on the merged TIF I get this error:
> Traceback (most recent call last):
>   File "/usr/bin/gdal2tiles.py", line 16, in <module>
>     sys.exit(main(sys.argv))
>   File "/usr/lib/python3/dist-packages/osgeo_utils/gdal2tiles.py", line
> 3314, in main
>     single_threaded_tiling(input_file, output_folder, options)
> 3229, in single_threaded_tiling
>     conf, tile_details = worker_tile_details(input_file, output_folder,
> options)
> 3145, in worker_tile_details
>     gdal2tiles.open_input()
> 1797, in open_input
>     self.warped_input_dataset = reproject_dataset(
> 987, in reproject_dataset
>     to_dataset = gdal.AutoCreateWarpedVRT(from_dataset,
>   File "/usr/lib/python3/dist-packages/osgeo/gdal.py", line 3976, in
> AutoCreateWarpedVRT
>     return _gdal.AutoCreateWarpedVRT(*args)
> `ENGCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere",EDATUM[""],CS[Cartesian,2],AXIS["easting",east,ORDER[1],LENGTHUNIT["metre",1,ID["EPSG",9001]]],AXIS["northing",north,ORDER[2],LENGTHUNIT["metre",1,ID["EPSG",9001]]]]'
> to `EPSG:3857'
> Aborted
> When I do gdalinfo on the merged TIF I get this:
> Corner Coordinates:
> Upper Left  (-10880978.065, 3538629.874)
> Lower Left  (-10880978.065, 3537702.774)
> Upper Right (-10880302.765, 3538629.874)
> Lower Right (-10880302.765, 3537702.774)
> Center      (-10880640.415, 3538166.324)
> When I do gdalinfo on the two TIFs that I merged I get this:
> Upper Left  (-10880811.355, 3538629.874)
> Lower Left  (-10880811.355, 3538052.574)
> Upper Right (-10880302.755, 3538629.874)
> Lower Right (-10880302.755, 3538052.574)
> Center      (-10880557.055, 3538341.224)
> ...and...
> Upper Left  (-10880978.065, 3538273.090)
> Lower Left  (-10880978.065, 3537702.790)
> Upper Right (-10880474.265, 3538273.090)
> Lower Right (-10880474.265, 3537702.790)
> Center      (-10880726.165, 3537987.940)
> Any ideas?
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221109/e133965a/attachment.htm>
