[gdal-dev] gdal2tiles: RuntimeError: Cannot find coordinate operations from `ENGCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere"
Even Rouault even.rouault at spatialys.com
Wed Nov 9 14:24:21 PST 2022
The GDAL version from ppa:ubuntugis/ppa on Ubuntu 20.04 is:
GDAL 3.3.2, released 2021/09/01
So there must be a mix of GDAL versions on your system if you have GDAL
3.4.3
Le 09/11/2022 à 23:13, Terra Frost a écrit :
> I installed the GDAL suite of tools by doing the following:
> sudo add-apt-repository ppa:ubuntugis/ppa
> sudo apt-get update
> sudo apt-get install gdal-bin
> sudo apt-get install libgdal-dev
> I'm running Ubuntu 20.04 and when I do gdal2tiles --version I get
> "GDAL 3.4.3, released 2022/04/22"
> On Wed, Nov 9, 2022 at 11:01 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Terra,
>     you didn't specify how you got GDAL and PROJ, and which versions
>     of those you use.
>     Make sure to solve the "proj_create_from_database: Cannot find
>     proj.db" error. Check if the PROJ_LIB environment is set and if it
>     points to the directory where proj.db is placed
>     The "free(): invalid pointer" error could also suggest that you
>     have several PROJ versions that are linked at runtime by GDAL.
>     Even
>     Le 09/11/2022 à 17:54, Terra Frost a écrit :
>>     I have two TIFs that I'm able to run gdal2tiles on without issue,
>>     however, when I do gdal_merge I am unable to do gdal2tiles on the
>>     result. When I did gdal_merge on the two TIFs I got this warning:
>>         Warning 1: PROJ: proj_create_from_database: Cannot find proj.db
>>         Warning 1: The definition of projected CRS EPSG:3857 got from
>>         GeoTIFF keys is not the same as the one from the EPSG
>>         registry, which may cause issues during reprojection
>>         operations. Set GTIFF_SRS_SOURCE configuration option to EPSG
>>         to use official parameters (overriding the ones from GeoTIFF
>>         keys), or to GEOKEYS to use custom values from GeoTIFF keys
>>         and drop the EPSG code.
>>         0...10...20...30...40...50...60...70...80...90...100 - done.
>>     Despite the warning the two TIFs merged without issue, however,
>>     when I try to run gdal2tiles on the merged TIF I get this error:
>>         Traceback (most recent call last):
>>           File "/usr/bin/gdal2tiles.py", line 16, in <module>
>>         sys.exit(main(sys.argv))
>>           File
>>         "/usr/lib/python3/dist-packages/osgeo_utils/gdal2tiles.py",
>>         line 3314, in main
>>         single_threaded_tiling(input_file, output_folder, options)
>>           File
>>         line 3229, in single_threaded_tiling
>>             conf, tile_details = worker_tile_details(input_file,
>>           File
>>         line 3145, in worker_tile_details
>>         gdal2tiles.open_input()
>>           File
>>         line 1797, in open_input
>>         self.warped_input_dataset = reproject_dataset(
>>           File
>>         line 987, in reproject_dataset
>>             to_dataset = gdal.AutoCreateWarpedVRT(from_dataset,
>>           File "/usr/lib/python3/dist-packages/osgeo/gdal.py", line
>>         3976, in AutoCreateWarpedVRT
>>             return _gdal.AutoCreateWarpedVRT(*args)
>>         `ENGCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere",EDATUM[""],CS[Cartesian,2],AXIS["easting",east,ORDER[1],LENGTHUNIT["metre",1,ID["EPSG",9001]]],AXIS["northing",north,ORDER[2],LENGTHUNIT["metre",1,ID["EPSG",9001]]]]'
>>         to `EPSG:3857'
>>         Aborted
>>     When I do gdalinfo on the merged TIF I get this:
>>         Corner Coordinates:
>>         Upper Left  (-10880978.065, 3538629.874)
>>         Lower Left  (-10880978.065, 3537702.774)
>>         Upper Right (-10880302.765, 3538629.874)
>>         Lower Right (-10880302.765, 3537702.774)
>>         Center  (-10880640.415, 3538166.324)
>>     When I do gdalinfo on the two TIFs that I merged I get this:
>>         Upper Left  (-10880811.355, 3538629.874)
>>         Lower Left  (-10880811.355, 3538052.574)
>>         Upper Right (-10880302.755, 3538629.874)
>>         Lower Right (-10880302.755, 3538052.574)
>>         Center  (-10880557.055, 3538341.224)
>>     ...and...
>>         Upper Left  (-10880978.065, 3538273.090)
>>         Lower Left  (-10880978.065, 3537702.790)
>>         Upper Right (-10880474.265, 3538273.090)
>>         Lower Right (-10880474.265, 3537702.790)
>>         Center  (-10880726.165, 3537987.940)
>>     Any ideas?
>>     _______________________________________________
>>     gdal-dev mailing list
>>     gdal-dev at lists.osgeo.org
>>     https://lists.osgeo.org/mailman/listinfo/gdal-dev
>     http://www.spatialys.com
>     My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221109/f2b18352/attachment-0001.htm>
