[gdal-dev] gdal2tiles: RuntimeError: Cannot find coordinate operations from `ENGCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere"
Terra Frost terrafrost at gmail.com
Wed Nov 9 15:23:06 PST 2022
So I just tried the above commands on a brand new Ubuntu 22.04 install.
When I did "sudo add-apt-repository ppa:ubuntugis/ppa" I got this error:
E: The repository 'https://ppa.launchpadcontent.net/ubuntugis/ppa/ubuntu
jammy Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore
disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration
details.
All the other commands worked but I guess they used another repo. The
attached output.txt is the output I got back when I did the sudo apt-get
install stuff.
Anyway, after all that, I'm still getting the same error.
I can make a video, from start to finish, showing the issue. I install
Ubuntu 22.04 on WSL2 from the Windows App Store and then I tell Ubuntu what
username I want to use and then I type in the commands. And then I copy the
TIF into the shared directory (\\wsl.localhost\Ubuntu-22.04\home\ubuntu)
and then I try the gdal2tiles command...
On Wed, Nov 9, 2022 at 4:24 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> The GDAL version from ppa:ubuntugis/ppa on Ubuntu 20.04 is:
> GDAL 3.3.2, released 2021/09/01
> So there must be a mix of GDAL versions on your system if you have GDAL
> 3.4.3
> Le 09/11/2022 à 23:13, Terra Frost a écrit :
> I installed the GDAL suite of tools by doing the following:
> sudo apt-get update
> sudo apt-get install gdal-bin
> sudo apt-get install libgdal-dev
> I'm running Ubuntu 20.04 and when I do gdal2tiles --version I get "GDAL
> 3.4.3, released 2022/04/22"
> On Wed, Nov 9, 2022 at 11:01 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Terra,
>> you didn't specify how you got GDAL and PROJ, and which versions of those
>> you use.
>> Make sure to solve the "proj_create_from_database: Cannot find proj.db"
>> error. Check if the PROJ_LIB environment is set and if it points to the
>> directory where proj.db is placed
>> The "free(): invalid pointer" error could also suggest that you have
>> several PROJ versions that are linked at runtime by GDAL.
>> Even
>> Le 09/11/2022 à 17:54, Terra Frost a écrit :
>> I have two TIFs that I'm able to run gdal2tiles on without issue,
>> however, when I do gdal_merge I am unable to do gdal2tiles on the
>> result. When I did gdal_merge on the two TIFs I got this warning:
>> Warning 1: PROJ: proj_create_from_database: Cannot find proj.db
>> Warning 1: The definition of projected CRS EPSG:3857 got from GeoTIFF
>> keys is not the same as the one from the EPSG registry, which may cause
>> issues during reprojection operations. Set GTIFF_SRS_SOURCE configuration
>> option to EPSG to use official parameters (overriding the ones from GeoTIFF
>> keys), or to GEOKEYS to use custom values from GeoTIFF keys and drop the
>> EPSG code.
>> EPSG code.
>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>> Despite the warning the two TIFs merged without issue, however, when I
>> try to run gdal2tiles on the merged TIF I get this error:
>> Traceback (most recent call last):
>>   File "/usr/bin/gdal2tiles.py", line 16, in <module>
>>     sys.exit(main(sys.argv))
>>   File "/usr/lib/python3/dist-packages/osgeo_utils/gdal2tiles.py", line
>> 3314, in main
>>     single_threaded_tiling(input_file, output_folder, options)
>> 3229, in single_threaded_tiling
>>     conf, tile_details = worker_tile_details(input_file, output_folder,
>> options)
>> 3145, in worker_tile_details
>>     gdal2tiles.open_input()
>> 1797, in open_input
>>     self.warped_input_dataset = reproject_dataset(
>> 987, in reproject_dataset
>>     to_dataset = gdal.AutoCreateWarpedVRT(from_dataset,
>>   File "/usr/lib/python3/dist-packages/osgeo/gdal.py", line 3976, in
>> AutoCreateWarpedVRT
>>     return _gdal.AutoCreateWarpedVRT(*args)
>> `ENGCRS["WGS_1984_Web_Mercator_Auxiliary_Sphere",EDATUM[""],CS[Cartesian,2],AXIS["easting",east,ORDER[1],LENGTHUNIT["metre",1,ID["EPSG",9001]]],AXIS["northing",north,ORDER[2],LENGTHUNIT["metre",1,ID["EPSG",9001]]]]'
>> to `EPSG:3857'
>> Aborted
>> When I do gdalinfo on the merged TIF I get this:
>> Corner Coordinates:
>> Upper Left  (-10880978.065, 3538629.874)
>> Lower Left  (-10880978.065, 3537702.774)
>> Upper Right (-10880302.765, 3538629.874)
>> Lower Right (-10880302.765, 3537702.774)
>> Center      (-10880640.415, 3538166.324)
>> When I do gdalinfo on the two TIFs that I merged I get this:
>> Upper Left  (-10880811.355, 3538629.874)
>> Lower Left  (-10880811.355, 3538052.574)
>> Upper Right (-10880302.755, 3538629.874)
>> Lower Right (-10880302.755, 3538052.574)
>> Center      (-10880557.055, 3538341.224)
>> ...and...
>> Upper Left  (-10880978.065, 3538273.090)
>> Lower Left  (-10880978.065, 3537702.790)
>> Upper Right (-10880474.265, 3538273.090)
>> Lower Right (-10880474.265, 3537702.790)
>> Center      (-10880726.165, 3537987.940)
>> Any ideas?
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221109/495d9f4b/attachment-0001.htm>
ubuntu at LAPTOP-STNJQ05O:~$ sudo apt-get install gdal-bin
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following additional packages will be installed:
  fontconfig-config fonts-dejavu-core gdal-data libaec0 libaom3 libarmadillo10 libarpack2 libblas3 libblosc1
  libcfitsio9 libcharls2 libdav1d5 libde265-0 libdeflate0 libfontconfig1 libfreetype6 libfreexl1 libfyba0 libgdal30
  libgeos-c1v5 libgeos3.10.2 libgeotiff5 libgfortran5 libgif7 libhdf4-0-alt libhdf5-103-1 libhdf5-hl-100 libheif1
  libjbig0 libjpeg-turbo8 libjpeg8 libkmlbase1 libkmldom1 libkmlengine1 liblapack3 liblcms2-2 libltdl7 libminizip1
  libmysqlclient21 libnetcdf19 libnspr4 libnss3 libodbc2 libodbcinst2 libogdi4.1 libopenjp2-7 libpoppler118 libpq5
  libproj22 libqhull-r8.0 libquadmath0 librttopo1 libsnappy1v5 libspatialite7 libsuperlu5 libsz2 libtiff5
  liburiparser1 libwebp7 libx265-199 libxerces-c3.2 mysql-common poppler-data proj-bin proj-data python3-gdal
  python3-numpy unixodbc-common
Suggested packages:
  libgdal-grass geotiff-bin libgeotiff-epsg libhdf4-doc libhdf4-alt-dev hdf4-tools liblcms2-utils odbc-postgresql
  tdsodbc ogdi-bin poppler-utils ghostscript fonts-japanese-mincho | fonts-ipafont-mincho fonts-japanese-gothic
  | fonts-ipafont-gothic fonts-arphic-ukai fonts-arphic-uming fonts-nanum gcc gfortran python-numpy-doc python3-dev
  python3-pytest
The following NEW packages will be installed:
  fontconfig-config fonts-dejavu-core gdal-bin gdal-data libaec0 libaom3 libarmadillo10 libarpack2 libblas3 libblosc1
0 upgraded, 69 newly installed, 0 to remove and 19 not upgraded.
Need to get 48.2 MB of archives.
After this operation, 182 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://archive.ubuntu.com/ubuntu jammy/main amd64 poppler-data all 0.4.11-1 [2171 kB]
Get:2 http://archive.ubuntu.com/ubuntu jammy/main amd64 fonts-dejavu-core all 2.37-2build1 [1041 kB]
Get:3 http://archive.ubuntu.com/ubuntu jammy/main amd64 fontconfig-config all 2.13.1-4.2ubuntu5 [29.1 kB]
Get:4 http://archive.ubuntu.com/ubuntu jammy/main amd64 libblas3 amd64 3.10.0-2ubuntu1 [228 kB]
Get:5 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libquadmath0 amd64 12.1.0-2ubuntu1~22.04 [154 kB]
Get:6 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libgfortran5 amd64 12.1.0-2ubuntu1~22.04 [882 kB]
Get:7 http://archive.ubuntu.com/ubuntu jammy/main amd64 liblapack3 amd64 3.10.0-2ubuntu1 [2504 kB]
Get:8 http://archive.ubuntu.com/ubuntu jammy/main amd64 python3-numpy amd64 1:1.21.5-1build2 [3464 kB]
Get:9 http://archive.ubuntu.com/ubuntu jammy/universe amd64 gdal-data all 3.4.1+dfsg-1build4 [216 kB]
Get:10 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libarpack2 amd64 3.8.0-1 [92.4 kB]
Get:11 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libsuperlu5 amd64 5.3.0+dfsg1-2 [183 kB]
Get:12 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libarmadillo10 amd64 1:10.8.2+dfsg-1 [105 kB]
Get:13 http://archive.ubuntu.com/ubuntu jammy/main amd64 libsnappy1v5 amd64 1.1.8-1build3 [17.5 kB]
Get:14 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libblosc1 amd64 1.21.1+ds2-2 [35.8 kB]
Get:15 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libcfitsio9 amd64 4.0.0-1 [519 kB]
Get:16 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libcharls2 amd64 2.3.4-1 [87.0 kB]
Get:17 http://archive.ubuntu.com/ubuntu jammy/main amd64 libdeflate0 amd64 1.10-2 [70.9 kB]
Get:18 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libfreexl1 amd64 1.0.6-1 [33.5 kB]
Get:19 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libfyba0 amd64 4.1.1-7 [113 kB]
Get:20 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libgeos3.10.2 amd64 3.10.2-1 [713 kB]
Get:21 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libgeos-c1v5 amd64 3.10.2-1 [82.5 kB]
Get:22 http://archive.ubuntu.com/ubuntu jammy/universe amd64 proj-data all 8.2.1-1 [10.0 MB]
Get:23 http://archive.ubuntu.com/ubuntu jammy/main amd64 libjbig0 amd64 2.1-3.1build3 [28.9 kB]
Get:24 http://archive.ubuntu.com/ubuntu jammy/main amd64 libjpeg-turbo8 amd64 2.1.2-0ubuntu1 [134 kB]
Get:25 http://archive.ubuntu.com/ubuntu jammy/main amd64 libjpeg8 amd64 8c-2ubuntu10 [2264 B]
Get:26 http://archive.ubuntu.com/ubuntu jammy/main amd64 libwebp7 amd64 1.2.2-2 [206 kB]
Get:27 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libtiff5 amd64 4.3.0-6ubuntu0.2 [184 kB]
Get:28 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libproj22 amd64 8.2.1-1 [1257 kB]
Get:29 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libgeotiff5 amd64 1.7.0-2build1 [67.1 kB]
Get:30 http://archive.ubuntu.com/ubuntu jammy/main amd64 libgif7 amd64 5.1.9-2build2 [33.8 kB]
Get:31 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libhdf4-0-alt amd64 4.2.15-4 [290 kB]
Get:32 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libaec0 amd64 1.0.6-1 [20.1 kB]
Get:33 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libsz2 amd64 1.0.6-1 [5354 B]
Get:34 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libhdf5-103-1 amd64 1.10.7+repack-4ubuntu2 [1295 kB]
Get:35 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libaom3 amd64 3.3.0-1 [1748 kB]
Get:36 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libdav1d5 amd64 0.9.2-1 [463 kB]
Get:37 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libde265-0 amd64 1.0.8-1 [243 kB]
Get:38 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libx265-199 amd64 3.5-2 [1170 kB]
Get:39 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libheif1 amd64 1.12.0-2build1 [196 kB]
Get:40 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libminizip1 amd64 1.1-8build1 [20.2 kB]
Get:41 http://archive.ubuntu.com/ubuntu jammy/universe amd64 liburiparser1 amd64 0.9.6+dfsg-1 [36.4 kB]
Get:42 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libkmlbase1 amd64 1.3.0-9 [45.0 kB]
Get:43 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libkmldom1 amd64 1.3.0-9 [150 kB]
Get:44 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libkmlengine1 amd64 1.3.0-9 [71.7 kB]
Get:45 http://archive.ubuntu.com/ubuntu jammy/main amd64 mysql-common all 5.8+1.0.8 [7212 B]
Get:46 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libmysqlclient21 amd64 8.0.31-0ubuntu0.22.04.1 [1301 kB]
Get:47 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libhdf5-hl-100 amd64 1.10.7+repack-4ubuntu2 [59.1 kB]
Get:48 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libnetcdf19 amd64 1:4.8.1-1 [456 kB]
Get:49 http://archive.ubuntu.com/ubuntu jammy/main amd64 libltdl7 amd64 2.4.6-15build2 [39.6 kB]
Get:50 http://archive.ubuntu.com/ubuntu jammy/main amd64 libodbc2 amd64 2.3.9-5 [159 kB]
Get:51 http://archive.ubuntu.com/ubuntu jammy/main amd64 unixodbc-common all 2.3.9-5 [9228 B]
Get:52 http://archive.ubuntu.com/ubuntu jammy/main amd64 libodbcinst2 amd64 2.3.9-5 [31.9 kB]
Get:53 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libogdi4.1 amd64 4.1.0+ds-5 [197 kB]
Get:54 http://archive.ubuntu.com/ubuntu jammy/main amd64 libopenjp2-7 amd64 2.4.0-6 [158 kB]
Get:55 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libfreetype6 amd64 2.11.1+dfsg-1ubuntu0.1 [389 kB]
Get:56 http://archive.ubuntu.com/ubuntu jammy/main amd64 libfontconfig1 amd64 2.13.1-4.2ubuntu5 [131 kB]
Get:57 http://archive.ubuntu.com/ubuntu jammy/main amd64 liblcms2-2 amd64 2.12~rc1-2build2 [159 kB]
Get:58 http://archive.ubuntu.com/ubuntu jammy/main amd64 libnspr4 amd64 2:4.32-3build1 [119 kB]
Get:59 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libnss3 amd64 2:3.68.2-0ubuntu1.1 [1280 kB]
Get:60 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpoppler118 amd64 22.02.0-2ubuntu0.1 [1077 kB]
Get:61 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpq5 amd64 14.5-0ubuntu0.22.04.1 [140 kB]
Get:62 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libqhull-r8.0 amd64 2020.2-4 [196 kB]
Get:63 http://archive.ubuntu.com/ubuntu jammy/universe amd64 librttopo1 amd64 1.1.0-2 [178 kB]
Get:64 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libspatialite7 amd64 5.0.1-2build2 [2092 kB]
Get:65 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libxerces-c3.2 amd64 3.2.3+debian-3build1 [930 kB]
Get:66 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libgdal30 amd64 3.4.1+dfsg-1build4 [7642 kB]
Get:67 http://archive.ubuntu.com/ubuntu jammy/universe amd64 python3-gdal amd64 3.4.1+dfsg-1build4 [673 kB]
Get:68 http://archive.ubuntu.com/ubuntu jammy/universe amd64 gdal-bin amd64 3.4.1+dfsg-1build4 [241 kB]
Get:69 http://archive.ubuntu.com/ubuntu jammy/universe amd64 proj-bin amd64 8.2.1-1 [154 kB]
Fetched 48.2 MB in 3s (17.3 MB/s)
Extracting templates from packages: 100%
Selecting previously unselected package poppler-data.
(Reading database ... 24075 files and directories currently installed.)
Preparing to unpack .../00-poppler-data_0.4.11-1_all.deb ...
Unpacking poppler-data (0.4.11-1) ...
Selecting previously unselected package fonts-dejavu-core.
Preparing to unpack .../01-fonts-dejavu-core_2.37-2build1_all.deb ...
Unpacking fonts-dejavu-core (2.37-2build1) ...
Selecting previously unselected package fontconfig-config.
Preparing to unpack .../02-fontconfig-config_2.13.1-4.2ubuntu5_all.deb ...
Unpacking fontconfig-config (2.13.1-4.2ubuntu5) ...
Selecting previously unselected package libblas3:amd64.
Preparing to unpack .../03-libblas3_3.10.0-2ubuntu1_amd64.deb ...
Unpacking libblas3:amd64 (3.10.0-2ubuntu1) ...
Selecting previously unselected package libquadmath0:amd64.
Preparing to unpack .../04-libquadmath0_12.1.0-2ubuntu1~22.04_amd64.deb ...
Unpacking libquadmath0:amd64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libgfortran5:amd64.
Preparing to unpack .../05-libgfortran5_12.1.0-2ubuntu1~22.04_amd64.deb ...
Unpacking libgfortran5:amd64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package liblapack3:amd64.
Preparing to unpack .../06-liblapack3_3.10.0-2ubuntu1_amd64.deb ...
Unpacking liblapack3:amd64 (3.10.0-2ubuntu1) ...
Selecting previously unselected package python3-numpy.
Preparing to unpack .../07-python3-numpy_1%3a1.21.5-1build2_amd64.deb ...
Unpacking python3-numpy (1:1.21.5-1build2) ...
Selecting previously unselected package gdal-data.
Preparing to unpack .../08-gdal-data_3.4.1+dfsg-1build4_all.deb ...
Unpacking gdal-data (3.4.1+dfsg-1build4) ...
Selecting previously unselected package libarpack2:amd64.
Preparing to unpack .../09-libarpack2_3.8.0-1_amd64.deb ...
Unpacking libarpack2:amd64 (3.8.0-1) ...
Selecting previously unselected package libsuperlu5:amd64.
Preparing to unpack .../10-libsuperlu5_5.3.0+dfsg1-2_amd64.deb ...
Unpacking libsuperlu5:amd64 (5.3.0+dfsg1-2) ...
Selecting previously unselected package libarmadillo10.
Preparing to unpack .../11-libarmadillo10_1%3a10.8.2+dfsg-1_amd64.deb ...
Unpacking libarmadillo10 (1:10.8.2+dfsg-1) ...
Selecting previously unselected package libsnappy1v5:amd64.
Preparing to unpack .../12-libsnappy1v5_1.1.8-1build3_amd64.deb ...
Unpacking libsnappy1v5:amd64 (1.1.8-1build3) ...
Selecting previously unselected package libblosc1:amd64.
Preparing to unpack .../13-libblosc1_1.21.1+ds2-2_amd64.deb ...
Unpacking libblosc1:amd64 (1.21.1+ds2-2) ...
Selecting previously unselected package libcfitsio9:amd64.
Preparing to unpack .../14-libcfitsio9_4.0.0-1_amd64.deb ...
Unpacking libcfitsio9:amd64 (4.0.0-1) ...
Selecting previously unselected package libcharls2:amd64.
Preparing to unpack .../15-libcharls2_2.3.4-1_amd64.deb ...
Unpacking libcharls2:amd64 (2.3.4-1) ...
Selecting previously unselected package libdeflate0:amd64.
Preparing to unpack .../16-libdeflate0_1.10-2_amd64.deb ...
Unpacking libdeflate0:amd64 (1.10-2) ...
Selecting previously unselected package libfreexl1:amd64.
Preparing to unpack .../17-libfreexl1_1.0.6-1_amd64.deb ...
Unpacking libfreexl1:amd64 (1.0.6-1) ...
Selecting previously unselected package libfyba0:amd64.
Preparing to unpack .../18-libfyba0_4.1.1-7_amd64.deb ...
Unpacking libfyba0:amd64 (4.1.1-7) ...
Selecting previously unselected package libgeos3.10.2:amd64.
Preparing to unpack .../19-libgeos3.10.2_3.10.2-1_amd64.deb ...
Unpacking libgeos3.10.2:amd64 (3.10.2-1) ...
Selecting previously unselected package libgeos-c1v5:amd64.
Preparing to unpack .../20-libgeos-c1v5_3.10.2-1_amd64.deb ...
Unpacking libgeos-c1v5:amd64 (3.10.2-1) ...
Selecting previously unselected package proj-data.
Preparing to unpack .../21-proj-data_8.2.1-1_all.deb ...
Unpacking proj-data (8.2.1-1) ...
Selecting previously unselected package libjbig0:amd64.
Preparing to unpack .../22-libjbig0_2.1-3.1build3_amd64.deb ...
Unpacking libjbig0:amd64 (2.1-3.1build3) ...
Selecting previously unselected package libjpeg-turbo8:amd64.
Preparing to unpack .../23-libjpeg-turbo8_2.1.2-0ubuntu1_amd64.deb ...
Unpacking libjpeg-turbo8:amd64 (2.1.2-0ubuntu1) ...
Selecting previously unselected package libjpeg8:amd64.
Preparing to unpack .../24-libjpeg8_8c-2ubuntu10_amd64.deb ...
Unpacking libjpeg8:amd64 (8c-2ubuntu10) ...
Selecting previously unselected package libwebp7:amd64.
Preparing to unpack .../25-libwebp7_1.2.2-2_amd64.deb ...
Unpacking libwebp7:amd64 (1.2.2-2) ...
Selecting previously unselected package libtiff5:amd64.
Preparing to unpack .../26-libtiff5_4.3.0-6ubuntu0.2_amd64.deb ...
Unpacking libtiff5:amd64 (4.3.0-6ubuntu0.2) ...
Selecting previously unselected package libproj22:amd64.
Preparing to unpack .../27-libproj22_8.2.1-1_amd64.deb ...
Unpacking libproj22:amd64 (8.2.1-1) ...
Selecting previously unselected package libgeotiff5:amd64.
Preparing to unpack .../28-libgeotiff5_1.7.0-2build1_amd64.deb ...
Unpacking libgeotiff5:amd64 (1.7.0-2build1) ...
Selecting previously unselected package libgif7:amd64.
Preparing to unpack .../29-libgif7_5.1.9-2build2_amd64.deb ...
Unpacking libgif7:amd64 (5.1.9-2build2) ...
Selecting previously unselected package libhdf4-0-alt.
Preparing to unpack .../30-libhdf4-0-alt_4.2.15-4_amd64.deb ...
Unpacking libhdf4-0-alt (4.2.15-4) ...
Selecting previously unselected package libaec0:amd64.
Preparing to unpack .../31-libaec0_1.0.6-1_amd64.deb ...
Unpacking libaec0:amd64 (1.0.6-1) ...
Selecting previously unselected package libsz2:amd64.
Preparing to unpack .../32-libsz2_1.0.6-1_amd64.deb ...
Unpacking libsz2:amd64 (1.0.6-1) ...
Selecting previously unselected package libhdf5-103-1:amd64.
Preparing to unpack .../33-libhdf5-103-1_1.10.7+repack-4ubuntu2_amd64.deb ...
Unpacking libhdf5-103-1:amd64 (1.10.7+repack-4ubuntu2) ...
Selecting previously unselected package libaom3:amd64.
Preparing to unpack .../34-libaom3_3.3.0-1_amd64.deb ...
Unpacking libaom3:amd64 (3.3.0-1) ...
Selecting previously unselected package libdav1d5:amd64.
Preparing to unpack .../35-libdav1d5_0.9.2-1_amd64.deb ...
Unpacking libdav1d5:amd64 (0.9.2-1) ...
Selecting previously unselected package libde265-0:amd64.
Preparing to unpack .../36-libde265-0_1.0.8-1_amd64.deb ...
Unpacking libde265-0:amd64 (1.0.8-1) ...
Selecting previously unselected package libx265-199:amd64.
Preparing to unpack .../37-libx265-199_3.5-2_amd64.deb ...
Unpacking libx265-199:amd64 (3.5-2) ...
Selecting previously unselected package libheif1:amd64.
Preparing to unpack .../38-libheif1_1.12.0-2build1_amd64.deb ...
Unpacking libheif1:amd64 (1.12.0-2build1) ...
Selecting previously unselected package libminizip1:amd64.
Preparing to unpack .../39-libminizip1_1.1-8build1_amd64.deb ...
Unpacking libminizip1:amd64 (1.1-8build1) ...
Selecting previously unselected package liburiparser1:amd64.
Preparing to unpack .../40-liburiparser1_0.9.6+dfsg-1_amd64.deb ...
Unpacking liburiparser1:amd64 (0.9.6+dfsg-1) ...
Selecting previously unselected package libkmlbase1:amd64.
Preparing to unpack .../41-libkmlbase1_1.3.0-9_amd64.deb ...
Unpacking libkmlbase1:amd64 (1.3.0-9) ...
Selecting previously unselected package libkmldom1:amd64.
Preparing to unpack .../42-libkmldom1_1.3.0-9_amd64.deb ...
Unpacking libkmldom1:amd64 (1.3.0-9) ...
Selecting previously unselected package libkmlengine1:amd64.
Preparing to unpack .../43-libkmlengine1_1.3.0-9_amd64.deb ...
Unpacking libkmlengine1:amd64 (1.3.0-9) ...
Selecting previously unselected package mysql-common.
Preparing to unpack .../44-mysql-common_5.8+1.0.8_all.deb ...
Unpacking mysql-common (5.8+1.0.8) ...
Selecting previously unselected package libmysqlclient21:amd64.
Preparing to unpack .../45-libmysqlclient21_8.0.31-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libmysqlclient21:amd64 (8.0.31-0ubuntu0.22.04.1) ...
Selecting previously unselected package libhdf5-hl-100:amd64.
Preparing to unpack .../46-libhdf5-hl-100_1.10.7+repack-4ubuntu2_amd64.deb ...
Unpacking libhdf5-hl-100:amd64 (1.10.7+repack-4ubuntu2) ...
Selecting previously unselected package libnetcdf19:amd64.
Preparing to unpack .../47-libnetcdf19_1%3a4.8.1-1_amd64.deb ...
Unpacking libnetcdf19:amd64 (1:4.8.1-1) ...
Selecting previously unselected package libltdl7:amd64.
Preparing to unpack .../48-libltdl7_2.4.6-15build2_amd64.deb ...
Unpacking libltdl7:amd64 (2.4.6-15build2) ...
Selecting previously unselected package libodbc2:amd64.
Preparing to unpack .../49-libodbc2_2.3.9-5_amd64.deb ...
Unpacking libodbc2:amd64 (2.3.9-5) ...
Selecting previously unselected package unixodbc-common.
Preparing to unpack .../50-unixodbc-common_2.3.9-5_all.deb ...
Unpacking unixodbc-common (2.3.9-5) ...
Selecting previously unselected package libodbcinst2:amd64.
Preparing to unpack .../51-libodbcinst2_2.3.9-5_amd64.deb ...
Unpacking libodbcinst2:amd64 (2.3.9-5) ...
Selecting previously unselected package libogdi4.1.
Preparing to unpack .../52-libogdi4.1_4.1.0+ds-5_amd64.deb ...
Unpacking libogdi4.1 (4.1.0+ds-5) ...
Selecting previously unselected package libopenjp2-7:amd64.
Preparing to unpack .../53-libopenjp2-7_2.4.0-6_amd64.deb ...
Unpacking libopenjp2-7:amd64 (2.4.0-6) ...
Selecting previously unselected package libfreetype6:amd64.
Preparing to unpack .../54-libfreetype6_2.11.1+dfsg-1ubuntu0.1_amd64.deb ...
Unpacking libfreetype6:amd64 (2.11.1+dfsg-1ubuntu0.1) ...
Selecting previously unselected package libfontconfig1:amd64.
Preparing to unpack .../55-libfontconfig1_2.13.1-4.2ubuntu5_amd64.deb ...
Unpacking libfontconfig1:amd64 (2.13.1-4.2ubuntu5) ...
Selecting previously unselected package liblcms2-2:amd64.
Preparing to unpack .../56-liblcms2-2_2.12~rc1-2build2_amd64.deb ...
Unpacking liblcms2-2:amd64 (2.12~rc1-2build2) ...
Selecting previously unselected package libnspr4:amd64.
Preparing to unpack .../57-libnspr4_2%3a4.32-3build1_amd64.deb ...
Unpacking libnspr4:amd64 (2:4.32-3build1) ...
Selecting previously unselected package libnss3:amd64.
Preparing to unpack .../58-libnss3_2%3a3.68.2-0ubuntu1.1_amd64.deb ...
Unpacking libnss3:amd64 (2:3.68.2-0ubuntu1.1) ...
Selecting previously unselected package libpoppler118:amd64.
Preparing to unpack .../59-libpoppler118_22.02.0-2ubuntu0.1_amd64.deb ...
Unpacking libpoppler118:amd64 (22.02.0-2ubuntu0.1) ...
Selecting previously unselected package libpq5:amd64.
Preparing to unpack .../60-libpq5_14.5-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libpq5:amd64 (14.5-0ubuntu0.22.04.1) ...
Selecting previously unselected package libqhull-r8.0:amd64.
Preparing to unpack .../61-libqhull-r8.0_2020.2-4_amd64.deb ...
Unpacking libqhull-r8.0:amd64 (2020.2-4) ...
Selecting previously unselected package librttopo1:amd64.
Preparing to unpack .../62-librttopo1_1.1.0-2_amd64.deb ...
Unpacking librttopo1:amd64 (1.1.0-2) ...
Selecting previously unselected package libspatialite7:amd64.
Preparing to unpack .../63-libspatialite7_5.0.1-2build2_amd64.deb ...
Unpacking libspatialite7:amd64 (5.0.1-2build2) ...
Selecting previously unselected package libxerces-c3.2:amd64.
Preparing to unpack .../64-libxerces-c3.2_3.2.3+debian-3build1_amd64.deb ...
Unpacking libxerces-c3.2:amd64 (3.2.3+debian-3build1) ...
Selecting previously unselected package libgdal30.
Preparing to unpack .../65-libgdal30_3.4.1+dfsg-1build4_amd64.deb ...
Unpacking libgdal30 (3.4.1+dfsg-1build4) ...
Selecting previously unselected package python3-gdal.
Preparing to unpack .../66-python3-gdal_3.4.1+dfsg-1build4_amd64.deb ...
Unpacking python3-gdal (3.4.1+dfsg-1build4) ...
Selecting previously unselected package gdal-bin.
Preparing to unpack .../67-gdal-bin_3.4.1+dfsg-1build4_amd64.deb ...
Unpacking gdal-bin (3.4.1+dfsg-1build4) ...
Selecting previously unselected package proj-bin.
Preparing to unpack .../68-proj-bin_8.2.1-1_amd64.deb ...
Unpacking proj-bin (8.2.1-1) ...
Setting up liblcms2-2:amd64 (2.12~rc1-2build2) ...
Setting up libgeos3.10.2:amd64 (3.10.2-1) ...
Setting up libaom3:amd64 (3.3.0-1) ...
Setting up mysql-common (5.8+1.0.8) ...
update-alternatives: using /etc/mysql/my.cnf.fallback to provide /etc/mysql/my.cnf (my.cnf) in auto mode
Setting up libmysqlclient21:amd64 (8.0.31-0ubuntu0.22.04.1) ...
Setting up libxerces-c3.2:amd64 (3.2.3+debian-3build1) ...
Setting up proj-data (8.2.1-1) ...
Setting up libogdi4.1 (4.1.0+ds-5) ...
Setting up libcharls2:amd64 (2.3.4-1) ...
Setting up libminizip1:amd64 (1.1-8build1) ...
Setting up libpq5:amd64 (14.5-0ubuntu0.22.04.1) ...
Setting up libdeflate0:amd64 (1.10-2) ...
Setting up libqhull-r8.0:amd64 (2020.2-4) ...
Setting up libjbig0:amd64 (2.1-3.1build3) ...
Setting up libaec0:amd64 (1.0.6-1) ...
Setting up gdal-data (3.4.1+dfsg-1build4) ...
Setting up libsnappy1v5:amd64 (1.1.8-1build3) ...
Setting up poppler-data (0.4.11-1) ...
Setting up libcfitsio9:amd64 (4.0.0-1) ...
Setting up libblas3:amd64 (3.10.0-2ubuntu1) ...
update-alternatives: using /usr/lib/x86_64-linux-gnu/blas/libblas.so.3 to provide /usr/lib/x86_64-linux-gnu/libblas.so.3 (libblas.so.3-x86_64-linux-gnu) in auto mode
Setting up libfreetype6:amd64 (2.11.1+dfsg-1ubuntu0.1) ...
Setting up libnspr4:amd64 (2:4.32-3build1) ...
Setting up libquadmath0:amd64 (12.1.0-2ubuntu1~22.04) ...
Setting up libgeos-c1v5:amd64 (3.10.2-1) ...
Setting up fonts-dejavu-core (2.37-2build1) ...
Setting up unixodbc-common (2.3.9-5) ...
Setting up libjpeg-turbo8:amd64 (2.1.2-0ubuntu1) ...
Setting up libltdl7:amd64 (2.4.6-15build2) ...
Setting up libgfortran5:amd64 (12.1.0-2ubuntu1~22.04) ...
Setting up libx265-199:amd64 (3.5-2) ...
Setting up libwebp7:amd64 (1.2.2-2) ...
Setting up libgif7:amd64 (5.1.9-2build2) ...
Setting up libodbc2:amd64 (2.3.9-5) ...
Setting up liburiparser1:amd64 (0.9.6+dfsg-1) ...
Setting up librttopo1:amd64 (1.1.0-2) ...
Setting up libfreexl1:amd64 (1.0.6-1) ...
Setting up libfyba0:amd64 (4.1.1-7) ...
Setting up libkmlbase1:amd64 (1.3.0-9) ...
Setting up libblosc1:amd64 (1.21.1+ds2-2) ...
Setting up libopenjp2-7:amd64 (2.4.0-6) ...
Setting up libdav1d5:amd64 (0.9.2-1) ...
Setting up libde265-0:amd64 (1.0.8-1) ...
Setting up libsz2:amd64 (1.0.6-1) ...
Setting up libkmldom1:amd64 (1.3.0-9) ...
Setting up libjpeg8:amd64 (8c-2ubuntu10) ...
Setting up libodbcinst2:amd64 (2.3.9-5) ...
Setting up liblapack3:amd64 (3.10.0-2ubuntu1) ...
update-alternatives: using /usr/lib/x86_64-linux-gnu/lapack/liblapack.so.3 to provide /usr/lib/x86_64-linux-gnu/liblapack.so.3 (liblapack.so.3-x86_64-linux-gnu) in auto mode
Setting up libkmlengine1:amd64 (1.3.0-9) ...
Setting up fontconfig-config (2.13.1-4.2ubuntu5) ...
Setting up libheif1:amd64 (1.12.0-2build1) ...
Setting up libarpack2:amd64 (3.8.0-1) ...
Setting up libsuperlu5:amd64 (5.3.0+dfsg1-2) ...
Setting up libnss3:amd64 (2:3.68.2-0ubuntu1.1) ...
Setting up python3-numpy (1:1.21.5-1build2) ...
Setting up libhdf4-0-alt (4.2.15-4) ...
Setting up libhdf5-103-1:amd64 (1.10.7+repack-4ubuntu2) ...
Setting up libtiff5:amd64 (4.3.0-6ubuntu0.2) ...
Setting up libfontconfig1:amd64 (2.13.1-4.2ubuntu5) ...
Setting up libhdf5-hl-100:amd64 (1.10.7+repack-4ubuntu2) ...
Setting up libarmadillo10 (1:10.8.2+dfsg-1) ...
Setting up libproj22:amd64 (8.2.1-1) ...
Setting up libgeotiff5:amd64 (1.7.0-2build1) ...
Setting up libpoppler118:amd64 (22.02.0-2ubuntu0.1) ...
Setting up libnetcdf19:amd64 (1:4.8.1-1) ...
Setting up libspatialite7:amd64 (5.0.1-2build2) ...
Setting up proj-bin (8.2.1-1) ...
Setting up libgdal30 (3.4.1+dfsg-1build4) ...
Setting up python3-gdal (3.4.1+dfsg-1build4) ...
Setting up gdal-bin (3.4.1+dfsg-1build4) ...
Processing triggers for man-db (2.10.2-1) ...
Processing triggers for libc-bin (2.35-0ubuntu3.1) ...
/sbin/ldconfig.real: /usr/lib/wsl/lib/libcuda.so.1 is not a symbolic link
ubuntu at LAPTOP-STNJQ05O:~$ sudo apt-get install libgdal-dev
  autoconf automake autotools-dev bzip2 cpp cpp-11 curl default-libmysqlclient-dev gcc gcc-11 gcc-11-base hdf5-helpers
  icu-devtools libaec-dev libaom-dev libarmadillo-dev libarpack2-dev libasan6 libatomic1 libblas-dev libblosc-dev
  libboost-dev libboost1.74-dev libc-dev-bin libc-devtools libc6-dev libcc1-0 libcfitsio-dev libcfitsio-doc
  libcharls-dev libcrypt-dev libcurl4 libcurl4-openssl-dev libdav1d-dev libde265-dev libdeflate-dev libdpkg-perl
  libexpat1-dev libfile-fcntllock-perl libfreexl-dev libfyba-dev libgcc-11-dev libgd3 libgeos-dev libgeotiff-dev
  libgif-dev libgomp1 libhdf4-alt-dev libhdf5-cpp-103-1 libhdf5-dev libhdf5-fortran-102 libhdf5-hl-cpp-100
  libhdf5-hl-fortran-100 libheif-dev libicu-dev libisl23 libitm1 libjbig-dev libjpeg-dev libjpeg-turbo8-dev
  libjpeg8-dev libjson-c-dev libkml-dev libkmlconvenience1 libkmlregionator1 libkmlxsd1 liblapack-dev liblsan0
  libltdl-dev liblz4-dev liblzma-dev libminizip-dev libmpc3 libmysqlclient-dev libnetcdf-dev libnsl-dev libodbccr2
  libogdi-dev libopenjp2-7-dev libpcre2-16-0 libpcre2-32-0 libpcre2-dev libpcre2-posix3 libpng-dev libpng-tools
  libpoppler-dev libpoppler-private-dev libpq-dev libproj-dev libqhull-dev libqhull8.0 libqhullcpp8.0 librttopo-dev
  libspatialite-dev libsqlite3-0 libsqlite3-dev libssl-dev libssl3 libstdc++-11-dev libsuperlu-dev libtiff-dev
  libtiffxx5 libtirpc-dev libtool libtsan0 libubsan1 liburiparser-dev libwebp-dev libwebpdemux2 libwebpmux3
  libx265-dev libxerces-c-dev libxml2-dev libxpm4 libzstd-dev linux-libc-dev m4 manpages-dev pkg-config rpcsvc-proto
  unixodbc-dev zlib1g-dev
Suggested packages:
  autoconf-archive gnu-standards autoconf-doc gettext bzip2-doc cpp-doc gcc-11-locales gcc-multilib make flex bison
  gdb gcc-doc gcc-11-multilib gcc-11-doc libitpp-dev liblapack-doc libboost-doc libboost1.74-doc
  libboost-atomic1.74-dev libboost-chrono1.74-dev libboost-container1.74-dev libboost-context1.74-dev
  libboost-contract1.74-dev libboost-coroutine1.74-dev libboost-date-time1.74-dev libboost-exception1.74-dev
  libboost-fiber1.74-dev libboost-filesystem1.74-dev libboost-graph1.74-dev libboost-graph-parallel1.74-dev
  libboost-iostreams1.74-dev libboost-locale1.74-dev libboost-log1.74-dev libboost-math1.74-dev libboost-mpi1.74-dev
  libboost-mpi-python1.74-dev libboost-numpy1.74-dev libboost-program-options1.74-dev libboost-python1.74-dev
  libboost-random1.74-dev libboost-regex1.74-dev libboost-serialization1.74-dev libboost-stacktrace1.74-dev
  libboost-system1.74-dev libboost-test1.74-dev libboost-thread1.74-dev libboost-timer1.74-dev
  libboost-type-erasure1.74-dev libboost-wave1.74-dev libboost1.74-tools-dev libmpfrc++-dev libntl-dev
  libboost-nowide1.74-dev glibc-doc libcurl4-doc libidn11-dev libkrb5-dev libldap2-dev librtmp-dev libssh2-1-dev
  debian-keyring bzr libgd-tools libgdal-doc libgeotiff-epsg libhdf5-doc icu-doc libtool-doc liblzma-doc netcdf-bin
  netcdf-doc libfreetype6-dev postgresql-doc-14 sqlite3-doc libssl-doc libstdc++-11-doc libsuperlu-doc gfortran
  | fortran95-compiler gcj-jdk libx265-doc libxerces-c-doc m4-doc dpkg-dev
  autoconf automake autotools-dev bzip2 cpp cpp-11 default-libmysqlclient-dev gcc gcc-11 gcc-11-base hdf5-helpers
  libcharls-dev libcrypt-dev libcurl4-openssl-dev libdav1d-dev libde265-dev libdeflate-dev libdpkg-perl libexpat1-dev
  libfile-fcntllock-perl libfreexl-dev libfyba-dev libgcc-11-dev libgd3 libgdal-dev libgeos-dev libgeotiff-dev
  libspatialite-dev libsqlite3-dev libssl-dev libstdc++-11-dev libsuperlu-dev libtiff-dev libtiffxx5 libtirpc-dev
  libtool libtsan0 libubsan1 liburiparser-dev libwebp-dev libwebpdemux2 libwebpmux3 libx265-dev libxerces-c-dev
  libxml2-dev libxpm4 libzstd-dev linux-libc-dev m4 manpages-dev pkg-config rpcsvc-proto unixodbc-dev zlib1g-dev
The following packages will be upgraded:
  curl libcurl4 libsqlite3-0 libssl3
4 upgraded, 119 newly installed, 0 to remove and 15 not upgraded.
Need to get 119 MB of archives.
After this operation, 613 MB of additional disk space will be used.
Get:1 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libssl3 amd64 3.0.2-0ubuntu1.7 [1899 kB]
Get:2 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libsqlite3-0 amd64 3.37.2-2ubuntu0.1 [641 kB]
Get:3 http://archive.ubuntu.com/ubuntu jammy/main amd64 m4 amd64 1.4.18-5ubuntu2 [199 kB]
Get:4 http://archive.ubuntu.com/ubuntu jammy/main amd64 autoconf all 2.71-2 [338 kB]
Get:5 http://archive.ubuntu.com/ubuntu jammy/main amd64 autotools-dev all 20220109.1 [44.9 kB]
Get:6 http://archive.ubuntu.com/ubuntu jammy/main amd64 automake all 1:1.16.5-1.3 [558 kB]
Get:7 http://archive.ubuntu.com/ubuntu jammy/main amd64 bzip2 amd64 1.0.8-5build1 [34.8 kB]
Get:8 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 gcc-11-base amd64 11.3.0-1ubuntu1~22.04 [20.8 kB]
Get:9 http://archive.ubuntu.com/ubuntu jammy/main amd64 libisl23 amd64 0.24-2build1 [727 kB]
Get:10 http://archive.ubuntu.com/ubuntu jammy/main amd64 libmpc3 amd64 1.2.1-2build1 [46.9 kB]
Get:11 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 cpp-11 amd64 11.3.0-1ubuntu1~22.04 [9967 kB]
Get:12 http://archive.ubuntu.com/ubuntu jammy/main amd64 cpp amd64 4:11.2.0-1ubuntu1 [27.7 kB]
Get:13 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 curl amd64 7.81.0-1ubuntu1.6 [194 kB]
Get:14 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libcurl4 amd64 7.81.0-1ubuntu1.6 [290 kB]
Get:15 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libssl-dev amd64 3.0.2-0ubuntu1.7 [2372 kB]
Get:16 http://archive.ubuntu.com/ubuntu jammy/main amd64 libzstd-dev amd64 1.4.8+dfsg-3build1 [401 kB]
Get:17 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libc-dev-bin amd64 2.35-0ubuntu3.1 [20.4 kB]
Get:18 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 linux-libc-dev amd64 5.15.0-52.58 [1319 kB]
Get:19 http://archive.ubuntu.com/ubuntu jammy/main amd64 libcrypt-dev amd64 1:4.4.27-1 [112 kB]
Get:20 http://archive.ubuntu.com/ubuntu jammy/main amd64 rpcsvc-proto amd64 1.4.2-0ubuntu6 [68.5 kB]
Get:21 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libtirpc-dev amd64 1.3.2-2ubuntu0.1 [192 kB]
Get:22 http://archive.ubuntu.com/ubuntu jammy/main amd64 libnsl-dev amd64 1.3.0-2build2 [71.3 kB]
Get:23 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libc6-dev amd64 2.35-0ubuntu3.1 [2099 kB]
Get:24 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 zlib1g-dev amd64 1:1.2.11.dfsg-2ubuntu9.2 [164 kB]
Get:25 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libmysqlclient-dev amd64 8.0.31-0ubuntu0.22.04.1 [1654 kB]
Get:26 http://archive.ubuntu.com/ubuntu jammy/main amd64 default-libmysqlclient-dev amd64 1.0.8 [3586 B]
Get:27 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libcc1-0 amd64 12.1.0-2ubuntu1~22.04 [47.4 kB]
Get:28 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libgomp1 amd64 12.1.0-2ubuntu1~22.04 [126 kB]
Get:29 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libitm1 amd64 12.1.0-2ubuntu1~22.04 [30.2 kB]
Get:30 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libatomic1 amd64 12.1.0-2ubuntu1~22.04 [10.4 kB]
Get:31 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libasan6 amd64 11.3.0-1ubuntu1~22.04 [2284 kB]
Get:32 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 liblsan0 amd64 12.1.0-2ubuntu1~22.04 [1069 kB]
Get:33 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libtsan0 amd64 11.3.0-1ubuntu1~22.04 [2262 kB]
Get:34 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libubsan1 amd64 12.1.0-2ubuntu1~22.04 [976 kB]
Get:35 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libgcc-11-dev amd64 11.3.0-1ubuntu1~22.04 [2517 kB]
Get:36 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 gcc-11 amd64 11.3.0-1ubuntu1~22.04 [20.1 MB]
Get:37 http://archive.ubuntu.com/ubuntu jammy/main amd64 gcc amd64 4:11.2.0-1ubuntu1 [5112 B]
Get:38 http://archive.ubuntu.com/ubuntu jammy/universe amd64 hdf5-helpers amd64 1.10.7+repack-4ubuntu2 [14.2 kB]
Get:39 http://archive.ubuntu.com/ubuntu jammy/main amd64 icu-devtools amd64 70.1-2 [197 kB]
Get:40 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libaom-dev amd64 3.3.0-1 [2094 kB]
Get:41 http://archive.ubuntu.com/ubuntu jammy/main amd64 libblas-dev amd64 3.10.0-2ubuntu1 [164 kB]
Get:42 http://archive.ubuntu.com/ubuntu jammy/main amd64 liblapack-dev amd64 3.10.0-2ubuntu1 [4774 kB]
Get:43 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libarpack2-dev amd64 3.8.0-1 [105 kB]
Get:44 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libhdf5-fortran-102 amd64 1.10.7+repack-4ubuntu2 [90.9 kB]
Get:45 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libhdf5-hl-fortran-100 amd64 1.10.7+repack-4ubuntu2 [33.8 kB]
Get:46 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libhdf5-cpp-103-1 amd64 1.10.7+repack-4ubuntu2 [129 kB]
Get:47 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libhdf5-hl-cpp-100 amd64 1.10.7+repack-4ubuntu2 [10.6 kB]
Get:48 http://archive.ubuntu.com/ubuntu jammy/main amd64 libjpeg-turbo8-dev amd64 2.1.2-0ubuntu1 [257 kB]
Get:49 http://archive.ubuntu.com/ubuntu jammy/main amd64 libjpeg8-dev amd64 8c-2ubuntu10 [1476 B]
Get:50 http://archive.ubuntu.com/ubuntu jammy/main amd64 libjpeg-dev amd64 8c-2ubuntu10 [1472 B]
Get:51 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libaec-dev amd64 1.0.6-1 [17.9 kB]
Get:52 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libcurl4-openssl-dev amd64 7.81.0-1ubuntu1.6 [385 kB]
Get:53 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libhdf5-dev amd64 1.10.7+repack-4ubuntu2 [2684 kB]
Get:54 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libsuperlu-dev amd64 5.3.0+dfsg1-2 [20.0 kB]
Get:55 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libarmadillo-dev amd64 1:10.8.2+dfsg-1 [399 kB]
Get:56 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libblosc-dev amd64 1.21.1+ds2-2 [44.1 kB]
Get:57 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libstdc++-11-dev amd64 11.3.0-1ubuntu1~22.04 [2087 kB]
Get:58 http://archive.ubuntu.com/ubuntu jammy/main amd64 libboost1.74-dev amd64 1.74.0-14ubuntu3 [9609 kB]
Get:59 http://archive.ubuntu.com/ubuntu jammy/main amd64 libboost-dev amd64 1.74.0.3ubuntu7 [3490 B]
Get:60 http://archive.ubuntu.com/ubuntu jammy/main amd64 libxpm4 amd64 1:3.5.12-1build2 [36.2 kB]
Get:61 http://archive.ubuntu.com/ubuntu jammy/main amd64 libgd3 amd64 2.3.0-2ubuntu2 [129 kB]
Get:62 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libc-devtools amd64 2.35-0ubuntu3.1 [28.9 kB]
Get:63 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libcfitsio-dev amd64 4.0.0-1 [591 kB]
Get:64 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libcfitsio-doc all 4.0.0-1 [2053 kB]
Get:65 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libcharls-dev amd64 2.3.4-1 [22.4 kB]
Get:66 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libdav1d-dev amd64 0.9.2-1 [24.1 kB]
Get:67 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libde265-dev amd64 1.0.8-1 [11.8 kB]
Get:68 http://archive.ubuntu.com/ubuntu jammy/main amd64 libdeflate-dev amd64 1.10-2 [59.2 kB]
Get:69 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libdpkg-perl all 1.21.1ubuntu2.1 [237 kB]
Get:70 http://archive.ubuntu.com/ubuntu jammy/main amd64 libexpat1-dev amd64 2.4.7-1 [147 kB]
Get:71 http://archive.ubuntu.com/ubuntu jammy/main amd64 libfile-fcntllock-perl amd64 0.22-3build7 [33.9 kB]
Get:72 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libfyba-dev amd64 4.1.1-7 [166 kB]
Get:73 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libgeos-dev amd64 3.10.2-1 [46.6 kB]
Get:74 http://archive.ubuntu.com/ubuntu jammy/main amd64 libgif-dev amd64 5.1.9-2build2 [22.4 kB]
Get:75 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libx265-dev amd64 3.5-2 [1374 kB]
Get:76 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libheif-dev amd64 1.12.0-2build1 [26.4 kB]
Get:77 http://archive.ubuntu.com/ubuntu jammy/main amd64 libicu-dev amd64 70.1-2 [11.6 MB]
Get:78 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libkmlconvenience1 amd64 1.3.0-9 [45.1 kB]
Get:79 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libkmlregionator1 amd64 1.3.0-9 [19.9 kB]
Get:80 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libkmlxsd1 amd64 1.3.0-9 [27.3 kB]
Get:81 http://archive.ubuntu.com/ubuntu jammy/main amd64 libltdl-dev amd64 2.4.6-15build2 [169 kB]
Get:82 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libminizip-dev amd64 1.1-8build1 [26.7 kB]
Get:83 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libnetcdf-dev amd64 1:4.8.1-1 [50.3 kB]
Get:84 http://archive.ubuntu.com/ubuntu jammy/main amd64 libodbccr2 amd64 2.3.9-5 [16.9 kB]
Get:85 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libogdi-dev amd64 4.1.0+ds-5 [22.1 kB]
Get:86 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpcre2-16-0 amd64 10.39-3ubuntu0.1 [203 kB]
Get:87 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpcre2-32-0 amd64 10.39-3ubuntu0.1 [194 kB]
Get:88 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpcre2-posix3 amd64 10.39-3ubuntu0.1 [6130 B]
Get:89 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpcre2-dev amd64 10.39-3ubuntu0.1 [730 kB]
Get:90 http://archive.ubuntu.com/ubuntu jammy/main amd64 libpng-dev amd64 1.6.37-3build5 [192 kB]
Get:91 http://archive.ubuntu.com/ubuntu jammy/main amd64 libpng-tools amd64 1.6.37-3build5 [28.7 kB]
Get:92 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpoppler-dev amd64 22.02.0-2ubuntu0.1 [5182 B]
Get:93 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpoppler-private-dev amd64 22.02.0-2ubuntu0.1 [198 kB]
Get:94 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libpq-dev amd64 14.5-0ubuntu0.22.04.1 [147 kB]
Get:95 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libqhull8.0 amd64 2020.2-4 [193 kB]
Get:96 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libqhullcpp8.0 amd64 2020.2-4 [53.0 kB]
Get:97 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libqhull-dev amd64 2020.2-4 [502 kB]
Get:98 http://archive.ubuntu.com/ubuntu jammy/universe amd64 librttopo-dev amd64 1.1.0-2 [220 kB]
Get:99 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libsqlite3-dev amd64 3.37.2-2ubuntu0.1 [846 kB]
Get:100 http://archive.ubuntu.com/ubuntu jammy/main amd64 libjbig-dev amd64 2.1-3.1build3 [27.3 kB]
Get:101 http://archive.ubuntu.com/ubuntu jammy/main amd64 liblzma-dev amd64 5.2.5-2ubuntu1 [159 kB]
Get:102 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libtiffxx5 amd64 4.3.0-6ubuntu0.2 [5734 B]
Get:103 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libtiff-dev amd64 4.3.0-6ubuntu0.2 [314 kB]
Get:104 http://archive.ubuntu.com/ubuntu jammy/main amd64 libtool all 2.4.6-15build2 [164 kB]
Get:105 http://archive.ubuntu.com/ubuntu jammy/universe amd64 liburiparser-dev amd64 0.9.6+dfsg-1 [12.2 kB]
Get:106 http://archive.ubuntu.com/ubuntu jammy/main amd64 libwebpdemux2 amd64 1.2.2-2 [9966 B]
Get:107 http://archive.ubuntu.com/ubuntu jammy/main amd64 libwebpmux3 amd64 1.2.2-2 [20.5 kB]
Get:108 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libxerces-c-dev amd64 3.2.3+debian-3build1 [1820 kB]
Get:109 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libxml2-dev amd64 2.9.13+dfsg-1ubuntu0.1 [803 kB]
Get:110 http://archive.ubuntu.com/ubuntu jammy/main amd64 manpages-dev all 5.10-1ubuntu1 [2309 kB]
Get:111 http://archive.ubuntu.com/ubuntu jammy/main amd64 pkg-config amd64 0.29.2-1ubuntu3 [48.2 kB]
Get:112 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libfreexl-dev amd64 1.0.6-1 [31.4 kB]
Get:113 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libproj-dev amd64 8.2.1-1 [1594 kB]
Get:114 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libgeotiff-dev amd64 1.7.0-2build1 [92.4 kB]
Get:115 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libhdf4-alt-dev amd64 4.2.15-4 [406 kB]
Get:116 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 libjson-c-dev amd64 0.15-3~ubuntu1.22.04.1 [60.5 kB]
Get:117 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libkml-dev amd64 1.3.0-9 [933 kB]
Get:118 http://archive.ubuntu.com/ubuntu jammy/main amd64 liblz4-dev amd64 1.9.3-2build2 [80.7 kB]
Get:119 http://archive.ubuntu.com/ubuntu jammy/main amd64 libopenjp2-7-dev amd64 2.4.0-6 [245 kB]
Get:120 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libspatialite-dev amd64 5.0.1-2build2 [2397 kB]
Get:121 http://archive.ubuntu.com/ubuntu jammy/main amd64 libwebp-dev amd64 1.2.2-2 [297 kB]
Get:122 http://archive.ubuntu.com/ubuntu jammy/main amd64 unixodbc-dev amd64 2.3.9-5 [248 kB]
Get:123 http://archive.ubuntu.com/ubuntu jammy/universe amd64 libgdal-dev amd64 3.4.1+dfsg-1build4 [10.6 MB]
Fetched 119 MB in 9s (13.3 MB/s)
Preconfiguring packages ...
(Reading database ... 26361 files and directories currently installed.)
Preparing to unpack .../libssl3_3.0.2-0ubuntu1.7_amd64.deb ...
Unpacking libssl3:amd64 (3.0.2-0ubuntu1.7) over (3.0.2-0ubuntu1.6) ...
Setting up libssl3:amd64 (3.0.2-0ubuntu1.7) ...
Preparing to unpack .../000-libsqlite3-0_3.37.2-2ubuntu0.1_amd64.deb ...
Unpacking libsqlite3-0:amd64 (3.37.2-2ubuntu0.1) over (3.37.2-2) ...
Selecting previously unselected package m4.
Preparing to unpack .../001-m4_1.4.18-5ubuntu2_amd64.deb ...
Unpacking m4 (1.4.18-5ubuntu2) ...
Selecting previously unselected package autoconf.
Preparing to unpack .../002-autoconf_2.71-2_all.deb ...
Unpacking autoconf (2.71-2) ...
Selecting previously unselected package autotools-dev.
Preparing to unpack .../003-autotools-dev_20220109.1_all.deb ...
Unpacking autotools-dev (20220109.1) ...
Selecting previously unselected package automake.
Preparing to unpack .../004-automake_1%3a1.16.5-1.3_all.deb ...
Unpacking automake (1:1.16.5-1.3) ...
Selecting previously unselected package bzip2.
Preparing to unpack .../005-bzip2_1.0.8-5build1_amd64.deb ...
Unpacking bzip2 (1.0.8-5build1) ...
Selecting previously unselected package gcc-11-base:amd64.
Preparing to unpack .../006-gcc-11-base_11.3.0-1ubuntu1~22.04_amd64.deb ...
Unpacking gcc-11-base:amd64 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package libisl23:amd64.
Preparing to unpack .../007-libisl23_0.24-2build1_amd64.deb ...
Unpacking libisl23:amd64 (0.24-2build1) ...
Selecting previously unselected package libmpc3:amd64.
Preparing to unpack .../008-libmpc3_1.2.1-2build1_amd64.deb ...
Unpacking libmpc3:amd64 (1.2.1-2build1) ...
Selecting previously unselected package cpp-11.
Preparing to unpack .../009-cpp-11_11.3.0-1ubuntu1~22.04_amd64.deb ...
Unpacking cpp-11 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package cpp.
Preparing to unpack .../010-cpp_4%3a11.2.0-1ubuntu1_amd64.deb ...
Unpacking cpp (4:11.2.0-1ubuntu1) ...
Preparing to unpack .../011-curl_7.81.0-1ubuntu1.6_amd64.deb ...
Unpacking curl (7.81.0-1ubuntu1.6) over (7.81.0-1ubuntu1.4) ...
Preparing to unpack .../012-libcurl4_7.81.0-1ubuntu1.6_amd64.deb ...
Unpacking libcurl4:amd64 (7.81.0-1ubuntu1.6) over (7.81.0-1ubuntu1.4) ...
Selecting previously unselected package libssl-dev:amd64.
Preparing to unpack .../013-libssl-dev_3.0.2-0ubuntu1.7_amd64.deb ...
Unpacking libssl-dev:amd64 (3.0.2-0ubuntu1.7) ...
Selecting previously unselected package libzstd-dev:amd64.
Preparing to unpack .../014-libzstd-dev_1.4.8+dfsg-3build1_amd64.deb ...
Unpacking libzstd-dev:amd64 (1.4.8+dfsg-3build1) ...
Selecting previously unselected package libc-dev-bin.
Preparing to unpack .../015-libc-dev-bin_2.35-0ubuntu3.1_amd64.deb ...
Unpacking libc-dev-bin (2.35-0ubuntu3.1) ...
Selecting previously unselected package linux-libc-dev:amd64.
Preparing to unpack .../016-linux-libc-dev_5.15.0-52.58_amd64.deb ...
Unpacking linux-libc-dev:amd64 (5.15.0-52.58) ...
Selecting previously unselected package libcrypt-dev:amd64.
Preparing to unpack .../017-libcrypt-dev_1%3a4.4.27-1_amd64.deb ...
Unpacking libcrypt-dev:amd64 (1:4.4.27-1) ...
Selecting previously unselected package rpcsvc-proto.
Preparing to unpack .../018-rpcsvc-proto_1.4.2-0ubuntu6_amd64.deb ...
Unpacking rpcsvc-proto (1.4.2-0ubuntu6) ...
Selecting previously unselected package libtirpc-dev:amd64.
Preparing to unpack .../019-libtirpc-dev_1.3.2-2ubuntu0.1_amd64.deb ...
Unpacking libtirpc-dev:amd64 (1.3.2-2ubuntu0.1) ...
Selecting previously unselected package libnsl-dev:amd64.
Preparing to unpack .../020-libnsl-dev_1.3.0-2build2_amd64.deb ...
Unpacking libnsl-dev:amd64 (1.3.0-2build2) ...
Selecting previously unselected package libc6-dev:amd64.
Preparing to unpack .../021-libc6-dev_2.35-0ubuntu3.1_amd64.deb ...
Unpacking libc6-dev:amd64 (2.35-0ubuntu3.1) ...
Selecting previously unselected package zlib1g-dev:amd64.
Preparing to unpack .../022-zlib1g-dev_1%3a1.2.11.dfsg-2ubuntu9.2_amd64.deb ...
Unpacking zlib1g-dev:amd64 (1:1.2.11.dfsg-2ubuntu9.2) ...
Selecting previously unselected package libmysqlclient-dev.
Preparing to unpack .../023-libmysqlclient-dev_8.0.31-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libmysqlclient-dev (8.0.31-0ubuntu0.22.04.1) ...
Selecting previously unselected package default-libmysqlclient-dev:amd64.
Preparing to unpack .../024-default-libmysqlclient-dev_1.0.8_amd64.deb ...
Unpacking default-libmysqlclient-dev:amd64 (1.0.8) ...
Selecting previously unselected package libcc1-0:amd64.
Preparing to unpack .../025-libcc1-0_12.1.0-2ubuntu1~22.04_amd64.deb ...
Unpacking libcc1-0:amd64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libgomp1:amd64.
Preparing to unpack .../026-libgomp1_12.1.0-2ubuntu1~22.04_amd64.deb ...
Unpacking libgomp1:amd64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libitm1:amd64.
Preparing to unpack .../027-libitm1_12.1.0-2ubuntu1~22.04_amd64.deb ...
Unpacking libitm1:amd64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libatomic1:amd64.
Preparing to unpack .../028-libatomic1_12.1.0-2ubuntu1~22.04_amd64.deb ...
Unpacking libatomic1:amd64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libasan6:amd64.
Preparing to unpack .../029-libasan6_11.3.0-1ubuntu1~22.04_amd64.deb ...
Unpacking libasan6:amd64 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package liblsan0:amd64.
Preparing to unpack .../030-liblsan0_12.1.0-2ubuntu1~22.04_amd64.deb ...
Unpacking liblsan0:amd64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libtsan0:amd64.
Preparing to unpack .../031-libtsan0_11.3.0-1ubuntu1~22.04_amd64.deb ...
Unpacking libtsan0:amd64 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package libubsan1:amd64.
Preparing to unpack .../032-libubsan1_12.1.0-2ubuntu1~22.04_amd64.deb ...
Unpacking libubsan1:amd64 (12.1.0-2ubuntu1~22.04) ...
Selecting previously unselected package libgcc-11-dev:amd64.
Preparing to unpack .../033-libgcc-11-dev_11.3.0-1ubuntu1~22.04_amd64.deb ...
Unpacking libgcc-11-dev:amd64 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package gcc-11.
Preparing to unpack .../034-gcc-11_11.3.0-1ubuntu1~22.04_amd64.deb ...
Unpacking gcc-11 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package gcc.
Preparing to unpack .../035-gcc_4%3a11.2.0-1ubuntu1_amd64.deb ...
Unpacking gcc (4:11.2.0-1ubuntu1) ...
Selecting previously unselected package hdf5-helpers.
Preparing to unpack .../036-hdf5-helpers_1.10.7+repack-4ubuntu2_amd64.deb ...
Unpacking hdf5-helpers (1.10.7+repack-4ubuntu2) ...
Selecting previously unselected package icu-devtools.
Preparing to unpack .../037-icu-devtools_70.1-2_amd64.deb ...
Unpacking icu-devtools (70.1-2) ...
Selecting previously unselected package libaom-dev:amd64.
Preparing to unpack .../038-libaom-dev_3.3.0-1_amd64.deb ...
Unpacking libaom-dev:amd64 (3.3.0-1) ...
Selecting previously unselected package libblas-dev:amd64.
Preparing to unpack .../039-libblas-dev_3.10.0-2ubuntu1_amd64.deb ...
Unpacking libblas-dev:amd64 (3.10.0-2ubuntu1) ...
Selecting previously unselected package liblapack-dev:amd64.
Preparing to unpack .../040-liblapack-dev_3.10.0-2ubuntu1_amd64.deb ...
Unpacking liblapack-dev:amd64 (3.10.0-2ubuntu1) ...
Selecting previously unselected package libarpack2-dev:amd64.
Preparing to unpack .../041-libarpack2-dev_3.8.0-1_amd64.deb ...
Unpacking libarpack2-dev:amd64 (3.8.0-1) ...
Selecting previously unselected package libhdf5-fortran-102:amd64.
Preparing to unpack .../042-libhdf5-fortran-102_1.10.7+repack-4ubuntu2_amd64.deb ...
Unpacking libhdf5-fortran-102:amd64 (1.10.7+repack-4ubuntu2) ...
Selecting previously unselected package libhdf5-hl-fortran-100:amd64.
Preparing to unpack .../043-libhdf5-hl-fortran-100_1.10.7+repack-4ubuntu2_amd64.deb ...
Unpacking libhdf5-hl-fortran-100:amd64 (1.10.7+repack-4ubuntu2) ...
Selecting previously unselected package libhdf5-cpp-103-1:amd64.
Preparing to unpack .../044-libhdf5-cpp-103-1_1.10.7+repack-4ubuntu2_amd64.deb ...
Unpacking libhdf5-cpp-103-1:amd64 (1.10.7+repack-4ubuntu2) ...
Selecting previously unselected package libhdf5-hl-cpp-100:amd64.
Preparing to unpack .../045-libhdf5-hl-cpp-100_1.10.7+repack-4ubuntu2_amd64.deb ...
Unpacking libhdf5-hl-cpp-100:amd64 (1.10.7+repack-4ubuntu2) ...
Selecting previously unselected package libjpeg-turbo8-dev:amd64.
Preparing to unpack .../046-libjpeg-turbo8-dev_2.1.2-0ubuntu1_amd64.deb ...
Unpacking libjpeg-turbo8-dev:amd64 (2.1.2-0ubuntu1) ...
Selecting previously unselected package libjpeg8-dev:amd64.
Preparing to unpack .../047-libjpeg8-dev_8c-2ubuntu10_amd64.deb ...
Unpacking libjpeg8-dev:amd64 (8c-2ubuntu10) ...
Selecting previously unselected package libjpeg-dev:amd64.
Preparing to unpack .../048-libjpeg-dev_8c-2ubuntu10_amd64.deb ...
Unpacking libjpeg-dev:amd64 (8c-2ubuntu10) ...
Selecting previously unselected package libaec-dev:amd64.
Preparing to unpack .../049-libaec-dev_1.0.6-1_amd64.deb ...
Unpacking libaec-dev:amd64 (1.0.6-1) ...
Selecting previously unselected package libcurl4-openssl-dev:amd64.
Preparing to unpack .../050-libcurl4-openssl-dev_7.81.0-1ubuntu1.6_amd64.deb ...
Unpacking libcurl4-openssl-dev:amd64 (7.81.0-1ubuntu1.6) ...
Selecting previously unselected package libhdf5-dev.
Preparing to unpack .../051-libhdf5-dev_1.10.7+repack-4ubuntu2_amd64.deb ...
Unpacking libhdf5-dev (1.10.7+repack-4ubuntu2) ...
Selecting previously unselected package libsuperlu-dev:amd64.
Preparing to unpack .../052-libsuperlu-dev_5.3.0+dfsg1-2_amd64.deb ...
Unpacking libsuperlu-dev:amd64 (5.3.0+dfsg1-2) ...
Selecting previously unselected package libarmadillo-dev.
Preparing to unpack .../053-libarmadillo-dev_1%3a10.8.2+dfsg-1_amd64.deb ...
Unpacking libarmadillo-dev (1:10.8.2+dfsg-1) ...
Selecting previously unselected package libblosc-dev.
Preparing to unpack .../054-libblosc-dev_1.21.1+ds2-2_amd64.deb ...
Unpacking libblosc-dev (1.21.1+ds2-2) ...
Selecting previously unselected package libstdc++-11-dev:amd64.
Preparing to unpack .../055-libstdc++-11-dev_11.3.0-1ubuntu1~22.04_amd64.deb ...
Unpacking libstdc++-11-dev:amd64 (11.3.0-1ubuntu1~22.04) ...
Selecting previously unselected package libboost1.74-dev:amd64.
Preparing to unpack .../056-libboost1.74-dev_1.74.0-14ubuntu3_amd64.deb ...
Unpacking libboost1.74-dev:amd64 (1.74.0-14ubuntu3) ...
Selecting previously unselected package libboost-dev:amd64.
Preparing to unpack .../057-libboost-dev_1.74.0.3ubuntu7_amd64.deb ...
Unpacking libboost-dev:amd64 (1.74.0.3ubuntu7) ...
Selecting previously unselected package libxpm4:amd64.
Preparing to unpack .../058-libxpm4_1%3a3.5.12-1build2_amd64.deb ...
Unpacking libxpm4:amd64 (1:3.5.12-1build2) ...
Selecting previously unselected package libgd3:amd64.
Preparing to unpack .../059-libgd3_2.3.0-2ubuntu2_amd64.deb ...
Unpacking libgd3:amd64 (2.3.0-2ubuntu2) ...
Selecting previously unselected package libc-devtools.
Preparing to unpack .../060-libc-devtools_2.35-0ubuntu3.1_amd64.deb ...
Unpacking libc-devtools (2.35-0ubuntu3.1) ...
Selecting previously unselected package libcfitsio-dev:amd64.
Preparing to unpack .../061-libcfitsio-dev_4.0.0-1_amd64.deb ...
Unpacking libcfitsio-dev:amd64 (4.0.0-1) ...
Selecting previously unselected package libcfitsio-doc.
Preparing to unpack .../062-libcfitsio-doc_4.0.0-1_all.deb ...
Unpacking libcfitsio-doc (4.0.0-1) ...
Selecting previously unselected package libcharls-dev:amd64.
Preparing to unpack .../063-libcharls-dev_2.3.4-1_amd64.deb ...
Unpacking libcharls-dev:amd64 (2.3.4-1) ...
Selecting previously unselected package libdav1d-dev:amd64.
Preparing to unpack .../064-libdav1d-dev_0.9.2-1_amd64.deb ...
Unpacking libdav1d-dev:amd64 (0.9.2-1) ...
Selecting previously unselected package libde265-dev:amd64.
Preparing to unpack .../065-libde265-dev_1.0.8-1_amd64.deb ...
Unpacking libde265-dev:amd64 (1.0.8-1) ...
Selecting previously unselected package libdeflate-dev:amd64.
Preparing to unpack .../066-libdeflate-dev_1.10-2_amd64.deb ...
Unpacking libdeflate-dev:amd64 (1.10-2) ...
Selecting previously unselected package libdpkg-perl.
Preparing to unpack .../067-libdpkg-perl_1.21.1ubuntu2.1_all.deb ...
Unpacking libdpkg-perl (1.21.1ubuntu2.1) ...
Selecting previously unselected package libexpat1-dev:amd64.
Preparing to unpack .../068-libexpat1-dev_2.4.7-1_amd64.deb ...
Unpacking libexpat1-dev:amd64 (2.4.7-1) ...
Selecting previously unselected package libfile-fcntllock-perl.
Preparing to unpack .../069-libfile-fcntllock-perl_0.22-3build7_amd64.deb ...
Unpacking libfile-fcntllock-perl (0.22-3build7) ...
Selecting previously unselected package libfyba-dev:amd64.
Preparing to unpack .../070-libfyba-dev_4.1.1-7_amd64.deb ...
Unpacking libfyba-dev:amd64 (4.1.1-7) ...
Selecting previously unselected package libgeos-dev.
Preparing to unpack .../071-libgeos-dev_3.10.2-1_amd64.deb ...
Unpacking libgeos-dev (3.10.2-1) ...
Selecting previously unselected package libgif-dev.
Preparing to unpack .../072-libgif-dev_5.1.9-2build2_amd64.deb ...
Unpacking libgif-dev (5.1.9-2build2) ...
Selecting previously unselected package libx265-dev:amd64.
Preparing to unpack .../073-libx265-dev_3.5-2_amd64.deb ...
Unpacking libx265-dev:amd64 (3.5-2) ...
Selecting previously unselected package libheif-dev:amd64.
Preparing to unpack .../074-libheif-dev_1.12.0-2build1_amd64.deb ...
Unpacking libheif-dev:amd64 (1.12.0-2build1) ...
Selecting previously unselected package libicu-dev:amd64.
Preparing to unpack .../075-libicu-dev_70.1-2_amd64.deb ...
Unpacking libicu-dev:amd64 (70.1-2) ...
Selecting previously unselected package libkmlconvenience1:amd64.
Preparing to unpack .../076-libkmlconvenience1_1.3.0-9_amd64.deb ...
Unpacking libkmlconvenience1:amd64 (1.3.0-9) ...
Selecting previously unselected package libkmlregionator1:amd64.
Preparing to unpack .../077-libkmlregionator1_1.3.0-9_amd64.deb ...
Unpacking libkmlregionator1:amd64 (1.3.0-9) ...
Selecting previously unselected package libkmlxsd1:amd64.
Preparing to unpack .../078-libkmlxsd1_1.3.0-9_amd64.deb ...
Unpacking libkmlxsd1:amd64 (1.3.0-9) ...
Selecting previously unselected package libltdl-dev:amd64.
Preparing to unpack .../079-libltdl-dev_2.4.6-15build2_amd64.deb ...
Unpacking libltdl-dev:amd64 (2.4.6-15build2) ...
Selecting previously unselected package libminizip-dev:amd64.
Preparing to unpack .../080-libminizip-dev_1.1-8build1_amd64.deb ...
Unpacking libminizip-dev:amd64 (1.1-8build1) ...
Selecting previously unselected package libnetcdf-dev.
Preparing to unpack .../081-libnetcdf-dev_1%3a4.8.1-1_amd64.deb ...
Unpacking libnetcdf-dev (1:4.8.1-1) ...
Selecting previously unselected package libodbccr2:amd64.
Preparing to unpack .../082-libodbccr2_2.3.9-5_amd64.deb ...
Unpacking libodbccr2:amd64 (2.3.9-5) ...
Selecting previously unselected package libogdi-dev.
Preparing to unpack .../083-libogdi-dev_4.1.0+ds-5_amd64.deb ...
Unpacking libogdi-dev (4.1.0+ds-5) ...
Selecting previously unselected package libpcre2-16-0:amd64.
Preparing to unpack .../084-libpcre2-16-0_10.39-3ubuntu0.1_amd64.deb ...
Unpacking libpcre2-16-0:amd64 (10.39-3ubuntu0.1) ...
Selecting previously unselected package libpcre2-32-0:amd64.
Preparing to unpack .../085-libpcre2-32-0_10.39-3ubuntu0.1_amd64.deb ...
Unpacking libpcre2-32-0:amd64 (10.39-3ubuntu0.1) ...
Selecting previously unselected package libpcre2-posix3:amd64.
Preparing to unpack .../086-libpcre2-posix3_10.39-3ubuntu0.1_amd64.deb ...
Unpacking libpcre2-posix3:amd64 (10.39-3ubuntu0.1) ...
Selecting previously unselected package libpcre2-dev:amd64.
Preparing to unpack .../087-libpcre2-dev_10.39-3ubuntu0.1_amd64.deb ...
Unpacking libpcre2-dev:amd64 (10.39-3ubuntu0.1) ...
Selecting previously unselected package libpng-dev:amd64.
Preparing to unpack .../088-libpng-dev_1.6.37-3build5_amd64.deb ...
Unpacking libpng-dev:amd64 (1.6.37-3build5) ...
Selecting previously unselected package libpng-tools.
Preparing to unpack .../089-libpng-tools_1.6.37-3build5_amd64.deb ...
Unpacking libpng-tools (1.6.37-3build5) ...
Selecting previously unselected package libpoppler-dev:amd64.
Preparing to unpack .../090-libpoppler-dev_22.02.0-2ubuntu0.1_amd64.deb ...
Unpacking libpoppler-dev:amd64 (22.02.0-2ubuntu0.1) ...
Selecting previously unselected package libpoppler-private-dev:amd64.
Preparing to unpack .../091-libpoppler-private-dev_22.02.0-2ubuntu0.1_amd64.deb ...
Unpacking libpoppler-private-dev:amd64 (22.02.0-2ubuntu0.1) ...
Selecting previously unselected package libpq-dev.
Preparing to unpack .../092-libpq-dev_14.5-0ubuntu0.22.04.1_amd64.deb ...
Unpacking libpq-dev (14.5-0ubuntu0.22.04.1) ...
Selecting previously unselected package libqhull8.0:amd64.
Preparing to unpack .../093-libqhull8.0_2020.2-4_amd64.deb ...
Unpacking libqhull8.0:amd64 (2020.2-4) ...
Selecting previously unselected package libqhullcpp8.0:amd64.
Preparing to unpack .../094-libqhullcpp8.0_2020.2-4_amd64.deb ...
Unpacking libqhullcpp8.0:amd64 (2020.2-4) ...
Selecting previously unselected package libqhull-dev:amd64.
Preparing to unpack .../095-libqhull-dev_2020.2-4_amd64.deb ...
Unpacking libqhull-dev:amd64 (2020.2-4) ...
Selecting previously unselected package librttopo-dev:amd64.
Preparing to unpack .../096-librttopo-dev_1.1.0-2_amd64.deb ...
Unpacking librttopo-dev:amd64 (1.1.0-2) ...
Selecting previously unselected package libsqlite3-dev:amd64.
Preparing to unpack .../097-libsqlite3-dev_3.37.2-2ubuntu0.1_amd64.deb ...
Unpacking libsqlite3-dev:amd64 (3.37.2-2ubuntu0.1) ...
Selecting previously unselected package libjbig-dev:amd64.
Preparing to unpack .../098-libjbig-dev_2.1-3.1build3_amd64.deb ...
Unpacking libjbig-dev:amd64 (2.1-3.1build3) ...
Selecting previously unselected package liblzma-dev:amd64.
Preparing to unpack .../099-liblzma-dev_5.2.5-2ubuntu1_amd64.deb ...
Unpacking liblzma-dev:amd64 (5.2.5-2ubuntu1) ...
Selecting previously unselected package libtiffxx5:amd64.
Preparing to unpack .../100-libtiffxx5_4.3.0-6ubuntu0.2_amd64.deb ...
Unpacking libtiffxx5:amd64 (4.3.0-6ubuntu0.2) ...
Selecting previously unselected package libtiff-dev:amd64.
Preparing to unpack .../101-libtiff-dev_4.3.0-6ubuntu0.2_amd64.deb ...
Unpacking libtiff-dev:amd64 (4.3.0-6ubuntu0.2) ...
Selecting previously unselected package libtool.
Preparing to unpack .../102-libtool_2.4.6-15build2_all.deb ...
Unpacking libtool (2.4.6-15build2) ...
Selecting previously unselected package liburiparser-dev.
Preparing to unpack .../103-liburiparser-dev_0.9.6+dfsg-1_amd64.deb ...
Unpacking liburiparser-dev (0.9.6+dfsg-1) ...
Selecting previously unselected package libwebpdemux2:amd64.
Preparing to unpack .../104-libwebpdemux2_1.2.2-2_amd64.deb ...
Unpacking libwebpdemux2:amd64 (1.2.2-2) ...
Selecting previously unselected package libwebpmux3:amd64.
Preparing to unpack .../105-libwebpmux3_1.2.2-2_amd64.deb ...
Unpacking libwebpmux3:amd64 (1.2.2-2) ...
Selecting previously unselected package libxerces-c-dev:amd64.
Preparing to unpack .../106-libxerces-c-dev_3.2.3+debian-3build1_amd64.deb ...
Unpacking libxerces-c-dev:amd64 (3.2.3+debian-3build1) ...
Selecting previously unselected package libxml2-dev:amd64.
Preparing to unpack .../107-libxml2-dev_2.9.13+dfsg-1ubuntu0.1_amd64.deb ...
Unpacking libxml2-dev:amd64 (2.9.13+dfsg-1ubuntu0.1) ...
Selecting previously unselected package manpages-dev.
Preparing to unpack .../108-manpages-dev_5.10-1ubuntu1_all.deb ...
Unpacking manpages-dev (5.10-1ubuntu1) ...
Selecting previously unselected package pkg-config.
Preparing to unpack .../109-pkg-config_0.29.2-1ubuntu3_amd64.deb ...
Unpacking pkg-config (0.29.2-1ubuntu3) ...
Selecting previously unselected package libfreexl-dev:amd64.
Preparing to unpack .../110-libfreexl-dev_1.0.6-1_amd64.deb ...
Unpacking libfreexl-dev:amd64 (1.0.6-1) ...
Selecting previously unselected package libproj-dev:amd64.
Preparing to unpack .../111-libproj-dev_8.2.1-1_amd64.deb ...
Unpacking libproj-dev:amd64 (8.2.1-1) ...
Selecting previously unselected package libgeotiff-dev:amd64.
Preparing to unpack .../112-libgeotiff-dev_1.7.0-2build1_amd64.deb ...
Unpacking libgeotiff-dev:amd64 (1.7.0-2build1) ...
Selecting previously unselected package libhdf4-alt-dev.
Preparing to unpack .../113-libhdf4-alt-dev_4.2.15-4_amd64.deb ...
Unpacking libhdf4-alt-dev (4.2.15-4) ...
Selecting previously unselected package libjson-c-dev:amd64.
Preparing to unpack .../114-libjson-c-dev_0.15-3~ubuntu1.22.04.1_amd64.deb ...
Unpacking libjson-c-dev:amd64 (0.15-3~ubuntu1.22.04.1) ...
Selecting previously unselected package libkml-dev:amd64.
Preparing to unpack .../115-libkml-dev_1.3.0-9_amd64.deb ...
Unpacking libkml-dev:amd64 (1.3.0-9) ...
Selecting previously unselected package liblz4-dev:amd64.
Preparing to unpack .../116-liblz4-dev_1.9.3-2build2_amd64.deb ...
Unpacking liblz4-dev:amd64 (1.9.3-2build2) ...
Selecting previously unselected package libopenjp2-7-dev:amd64.
Preparing to unpack .../117-libopenjp2-7-dev_2.4.0-6_amd64.deb ...
Unpacking libopenjp2-7-dev:amd64 (2.4.0-6) ...
Selecting previously unselected package libspatialite-dev:amd64.
Preparing to unpack .../118-libspatialite-dev_5.0.1-2build2_amd64.deb ...
Unpacking libspatialite-dev:amd64 (5.0.1-2build2) ...
Selecting previously unselected package libwebp-dev:amd64.
Preparing to unpack .../119-libwebp-dev_1.2.2-2_amd64.deb ...
Unpacking libwebp-dev:amd64 (1.2.2-2) ...
Selecting previously unselected package unixodbc-dev:amd64.
Preparing to unpack .../120-unixodbc-dev_2.3.9-5_amd64.deb ...
Unpacking unixodbc-dev:amd64 (2.3.9-5) ...
Selecting previously unselected package libgdal-dev.
Preparing to unpack .../121-libgdal-dev_3.4.1+dfsg-1build4_amd64.deb ...
Unpacking libgdal-dev (3.4.1+dfsg-1build4) ...
Setting up libpoppler-dev:amd64 (22.02.0-2ubuntu0.1) ...
Setting up gcc-11-base:amd64 (11.3.0-1ubuntu1~22.04) ...
Setting up librttopo-dev:amd64 (1.1.0-2) ...
Setting up manpages-dev (5.10-1ubuntu1) ...
Setting up libcharls-dev:amd64 (2.3.4-1) ...
Setting up libcfitsio-dev:amd64 (4.0.0-1) ...
Setting up libzstd-dev:amd64 (1.4.8+dfsg-3build1) ...
Setting up libxpm4:amd64 (1:3.5.12-1build2) ...
Setting up hdf5-helpers (1.10.7+repack-4ubuntu2) ...
Setting up libkmlconvenience1:amd64 (1.3.0-9) ...
Setting up libpng-tools (1.6.37-3build5) ...
Setting up libqhull8.0:amd64 (2020.2-4) ...
Setting up libfile-fcntllock-perl (0.22-3build7) ...
Setting up libblosc-dev (1.21.1+ds2-2) ...
Setting up libjson-c-dev:amd64 (0.15-3~ubuntu1.22.04.1) ...
Setting up libfreexl-dev:amd64 (1.0.6-1) ...
Setting up libfyba-dev:amd64 (4.1.1-7) ...
Setting up libwebpdemux2:amd64 (1.2.2-2) ...
Setting up libpoppler-private-dev:amd64 (22.02.0-2ubuntu0.1) ...
Setting up libsqlite3-0:amd64 (3.37.2-2ubuntu0.1) ...
Setting up libaec-dev:amd64 (1.0.6-1) ...
Setting up libjbig-dev:amd64 (2.1-3.1build3) ...
Setting up linux-libc-dev:amd64 (5.15.0-52.58) ...
Setting up m4 (1.4.18-5ubuntu2) ...
Setting up libgomp1:amd64 (12.1.0-2ubuntu1~22.04) ...
Setting up bzip2 (1.0.8-5build1) ...
Setting up libpcre2-16-0:amd64 (10.39-3ubuntu0.1) ...
Setting up libasan6:amd64 (11.3.0-1ubuntu1~22.04) ...
Setting up liburiparser-dev (0.9.6+dfsg-1) ...
Setting up libaom-dev:amd64 (3.3.0-1) ...
Setting up libminizip-dev:amd64 (1.1-8build1) ...
Setting up autotools-dev (20220109.1) ...
Setting up libpcre2-32-0:amd64 (10.39-3ubuntu0.1) ...
Setting up libhdf5-hl-cpp-100:amd64 (1.10.7+repack-4ubuntu2) ...
Setting up libtirpc-dev:amd64 (1.3.2-2ubuntu0.1) ...
Setting up rpcsvc-proto (1.4.2-0ubuntu6) ...
Setting up libde265-dev:amd64 (1.0.8-1) ...
Setting up libopenjp2-7-dev:amd64 (2.4.0-6) ...
Setting up libkmlregionator1:amd64 (1.3.0-9) ...
Setting up libgeos-dev (3.10.2-1) ...
Setting up libdav1d-dev:amd64 (0.9.2-1) ...
Setting up libx265-dev:amd64 (3.5-2) ...
Setting up libgd3:amd64 (2.3.0-2ubuntu2) ...
Setting up libssl-dev:amd64 (3.0.2-0ubuntu1.7) ...
Setting up libmpc3:amd64 (1.2.1-2build1) ...
Setting up libatomic1:amd64 (12.1.0-2ubuntu1~22.04) ...
Setting up libhdf5-fortran-102:amd64 (1.10.7+repack-4ubuntu2) ...
Setting up icu-devtools (70.1-2) ...
Setting up liblz4-dev:amd64 (1.9.3-2build2) ...
Setting up libqhullcpp8.0:amd64 (2020.2-4) ...
Setting up libqhull-dev:amd64 (2020.2-4) ...
Setting up libdpkg-perl (1.21.1ubuntu2.1) ...
Setting up autoconf (2.71-2) ...
Setting up liblzma-dev:amd64 (5.2.5-2ubuntu1) ...
Setting up libubsan1:amd64 (12.1.0-2ubuntu1~22.04) ...
Setting up libpcre2-posix3:amd64 (10.39-3ubuntu0.1) ...
Setting up libnsl-dev:amd64 (1.3.0-2build2) ...
Setting up libgif-dev (5.1.9-2build2) ...
Setting up libcrypt-dev:amd64 (1:4.4.27-1) ...
Setting up libhdf5-cpp-103-1:amd64 (1.10.7+repack-4ubuntu2) ...
Setting up libhdf5-hl-fortran-100:amd64 (1.10.7+repack-4ubuntu2) ...
Setting up libcurl4:amd64 (7.81.0-1ubuntu1.6) ...
Setting up curl (7.81.0-1ubuntu1.6) ...
Setting up libisl23:amd64 (0.24-2build1) ...
Setting up libc-dev-bin (2.35-0ubuntu3.1) ...
Setting up libwebpmux3:amd64 (1.2.2-2) ...
Setting up libdeflate-dev:amd64 (1.10-2) ...
Setting up libogdi-dev (4.1.0+ds-5) ...
Setting up libcfitsio-doc (4.0.0-1) ...
Setting up libcc1-0:amd64 (12.1.0-2ubuntu1~22.04) ...
Setting up liblsan0:amd64 (12.1.0-2ubuntu1~22.04) ...
Setting up libblas-dev:amd64 (3.10.0-2ubuntu1) ...
update-alternatives: using /usr/lib/x86_64-linux-gnu/blas/libblas.so to provide /usr/lib/x86_64-linux-gnu/libblas.so (libblas.so-x86_64-linux-gnu) in auto mode
Setting up libitm1:amd64 (12.1.0-2ubuntu1~22.04) ...
Setting up libkmlxsd1:amd64 (1.3.0-9) ...
Setting up libtiffxx5:amd64 (4.3.0-6ubuntu0.2) ...
Setting up libc-devtools (2.35-0ubuntu3.1) ...
Setting up libodbccr2:amd64 (2.3.9-5) ...
Setting up libtsan0:amd64 (11.3.0-1ubuntu1~22.04) ...
Setting up automake (1:1.16.5-1.3) ...
update-alternatives: using /usr/bin/automake-1.16 to provide /usr/bin/automake (automake) in auto mode
Setting up cpp-11 (11.3.0-1ubuntu1~22.04) ...
Setting up libheif-dev:amd64 (1.12.0-2build1) ...
Setting up libpq-dev (14.5-0ubuntu0.22.04.1) ...
Setting up libltdl-dev:amd64 (2.4.6-15build2) ...
Setting up libwebp-dev:amd64 (1.2.2-2) ...
Setting up libcurl4-openssl-dev:amd64 (7.81.0-1ubuntu1.6) ...
Setting up liblapack-dev:amd64 (3.10.0-2ubuntu1) ...
update-alternatives: using /usr/lib/x86_64-linux-gnu/lapack/liblapack.so to provide /usr/lib/x86_64-linux-gnu/liblapack.so (liblapack.so-x86_64-linux-gnu) in auto mode
Setting up pkg-config (0.29.2-1ubuntu3) ...
Setting up libgcc-11-dev:amd64 (11.3.0-1ubuntu1~22.04) ...
Setting up gcc-11 (11.3.0-1ubuntu1~22.04) ...
Setting up cpp (4:11.2.0-1ubuntu1) ...
Setting up libc6-dev:amd64 (2.35-0ubuntu3.1) ...
Setting up libsuperlu-dev:amd64 (5.3.0+dfsg1-2) ...
Setting up libicu-dev:amd64 (70.1-2) ...
Setting up unixodbc-dev:amd64 (2.3.9-5) ...
Setting up libjpeg-turbo8-dev:amd64 (2.1.2-0ubuntu1) ...
Setting up libarpack2-dev:amd64 (3.8.0-1) ...
Setting up libpcre2-dev:amd64 (10.39-3ubuntu0.1) ...
Setting up libtool (2.4.6-15build2) ...
Setting up gcc (4:11.2.0-1ubuntu1) ...
Setting up libxml2-dev:amd64 (2.9.13+dfsg-1ubuntu0.1) ...
Setting up libexpat1-dev:amd64 (2.4.7-1) ...
Setting up libsqlite3-dev:amd64 (3.37.2-2ubuntu0.1) ...
Setting up libxerces-c-dev:amd64 (3.2.3+debian-3build1) ...
Setting up libstdc++-11-dev:amd64 (11.3.0-1ubuntu1~22.04) ...
Setting up zlib1g-dev:amd64 (1:1.2.11.dfsg-2ubuntu9.2) ...
Setting up libjpeg8-dev:amd64 (8c-2ubuntu10) ...
Setting up libmysqlclient-dev (8.0.31-0ubuntu0.22.04.1) ...
Setting up default-libmysqlclient-dev:amd64 (1.0.8) ...
Setting up libboost1.74-dev:amd64 (1.74.0-14ubuntu3) ...
Setting up libpng-dev:amd64 (1.6.37-3build5) ...
Setting up libjpeg-dev:amd64 (8c-2ubuntu10) ...
Setting up libtiff-dev:amd64 (4.3.0-6ubuntu0.2) ...
Setting up libhdf5-dev (1.10.7+repack-4ubuntu2) ...
update-alternatives: using /usr/lib/x86_64-linux-gnu/pkgconfig/hdf5-serial.pc to provide /usr/lib/x86_64-linux-gnu/pkgconfig/hdf5.pc (hdf5.pc) in auto mode
Setting up libproj-dev:amd64 (8.2.1-1) ...
Setting up libnetcdf-dev (1:4.8.1-1) ...
Setting up libspatialite-dev:amd64 (5.0.1-2build2) ...
Setting up libboost-dev:amd64 (1.74.0.3ubuntu7) ...
Setting up libkml-dev:amd64 (1.3.0-9) ...
Setting up libgeotiff-dev:amd64 (1.7.0-2build1) ...
Setting up libarmadillo-dev (1:10.8.2+dfsg-1) ...
Setting up libhdf4-alt-dev (4.2.15-4) ...
Setting up libgdal-dev (3.4.1+dfsg-1build4) ...
Processing triggers for install-info (6.8-4build1) ...
