[gdal-dev] not enough disk space for gdal_merge even though I have ~1TB free
Terra Frost terrafrost at gmail.com
Wed Nov 9 14:20:35 PST 2022
When I do "gdal_merge -o result.tif bottom.tif top.tif" I get the following
error:
ERROR 3: result.tif: Free disk space available is 1011663560704 bytes,
whereas 61588097799713184 are at least necessary. You can disable this
check by defining the CHECK_DISK_FREE_SPACE configuration option to FALSE.
Creation failed, terminating gdal_merge.
I don't understand. The two TIFs I'm trying to merge are 1.27GB and 64MB
and it's saying 61588097799713184 bytes are needed? That's 61.58 PB. Why
would gdal_merge think it'd need 61.58 PB?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221109/c6dc9961/attachment.htm>
