[gdal-dev] openfilegdb export
Andrew Terry andrew.terry at centremaps.co.uk
Fri Nov 11 06:27:10 PST 2022
Thanks Even, -nlt POLYGON did indeed work for me.
Huge thanks as always for your (and every contributor’s) amazing work.
Andy
Sent: 11 November 2022 14:07
To: Andrew Terry <andrew.terry at centremaps.co.uk>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] openfilegdb export
Andrew,
Can you paste the output of
ogrinfo -al -so PG:"dbname=dbname port=5432 host=dbhost user=dbusr" --optfile sql_filter.sql
so we can see the layer geometry type. I presume it is unknown.
GeoPackage supports geometry columns with unknown geometry type.
Shapefile requires a precise geometry type, but the shapefile driver has a heuristics to use the geometry type of the first feature as the layer geometry type, when the declared layer geometry type is unknown. The OpenFileGDB driver doesn't have that heuristics.
It is likely you need to add an explicit -nlt POLYGON or -nlt MULTIPOLYGON to your ogr2ogr invokation
Even
Le 11/11/2022 à 14:53, Andrew Terry a écrit :
Trying out the export to OpenFileGDB, using GDAL 3.7.0dev-5a6f99a78b installed with OSGeo4W
ogr2ogr -f "OpenFileGDB" test_filegdb.gdb PG:"dbname=dbname port=5432 host=dbhost user=dbusr" --optfile sql_filter.sql
This works for SHP and GeoPackage and the output is a EPSG 27700 Polygon geometries.
I get the following error:
ERROR 6: Unsupported geometry type
ERROR 1: Terminating translation prematurely after failed
translation from sql statement.
What geometry type is expected? I did try ST_Multi and ST_Force3D to see whether multipolygons etc are expected.
Hopefully I’m not missing something too obvious.
Thanks
Andy
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221111/5b230513/attachment.htm>
