[gdal-dev] Save min/max values in TIFF
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Nov 11 10:12:19 PST 2022
Hi
I am creating a GeoTIFF file with C++. It is a large DSM (one band of
Float32). Because I am generating it, I already know the min and max values.
I would like to store the min and max values directly in the TIFF, not in a
sidecar file. Is there any gdal metadata (stored in the TIFF) that can be
used? That way, when I open it in QGIS, the range of the band will be
accurate.
Thanks.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221111/0fb67799/attachment-0001.htm>
