[gdal-dev] Motion: adopt RFC 87: Signed int8 data type for raster
Hermann Rodrigues hermann.rodrigues at gmail.com
Wed Nov 16 09:08:46 PST 2022
So based on that RFC it is a breaking change when reading signed images. I
confess that this type of silent behavor change scares me.
Why dont make this an opt-in behavior instead of just breaking application
code silently? Otherwise, I would rather have GDT_Byte removed so that
application code would not compile against new versions of GDAL. At least
that makes migration to new versions less risky.
Best,
hermann
Hermann Rodrigues
hermann at csr.ufmg.br
Twitter: @horodrigues | @dinamica_ego
Centro de Sensoriamento Remoto / UFMG
https://csr.ufmg.br | https://dinamicaego.com
On Wed, Nov 16, 2022 at 11:38 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Le 16/11/2022 à 17:32, Hermann Rodrigues a écrit :
> Hi,
> I am a bit late for this discussion, but can someone please clarify if
> this is a breaking change? Is this keeping the old behavior in place when
> reading GDT_Byte or replacing it completely when reading rasters storing
> 8-bit pixels?
> This doesn't affect GDT_Byte rasters that were really unsigned 8-bit
> pixels.
> For signed 8-bit pixels,
> https://gdal.org/development/rfc/rfc87_signed_int8.html#backward-compatibility
> should answer your question
> Best,
> hermann
> Hermann Rodrigues
> On Wed, Nov 16, 2022 at 8:04 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> I declare this motion passed with +1 from PSC members KurtS, JukkaR,
>> MateuszL and me.
>> Even
>> Le 14/11/2022 à 13:22, Even Rouault a écrit :
>> > Hi,
>> > I feel the discussion phase has finished. There were a few questions
>> > about the existing GDT_Byte unsigned 8-bit integer type, if it should
>> > be renamed/aliased/etc, but no obvious conclusion emerged from this,
>> > and I'd suggest we keep with the status-quo with GDT_Byte, and the RFC
>> > remains on just adding GDT_Int8 for signed 8-bit integer.
>> > Motion:
>> > Adopt RFC 87: Signed int8 data type for raster
>> > (https://github.com/OSGeo/gdal/pull/6634)
>> > Starting with my +1,
>> > Even
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221116/3174004d/attachment-0001.htm>
