[gdal-dev] Motion: adopt RFC 87: Signed int8 data type for raster
Even Rouault even.rouault at spatialys.com
Wed Nov 16 09:38:16 PST 2022
> So based on that RFC it is a breaking change when reading signed
> images. I confess that this type of silent behavor change scares me.
It is documented in
https://github.com/OSGeo/gdal/blob/master/MIGRATION_GUIDE.TXT which is
always referenced in the release notes.
> Why dont make this an opt-in behavior instead of just breaking
> application code silently?
Opt-in behaviour would mean clutering the GDAL code base even more, to
implement both the legacy and the new behavior. One of the purposes of
the RFC was to de-clutter the GDAL code base.
> Otherwise, I would rather have GDT_Byte removed so that application
> code would not compile against new versions of GDAL. At least that
> makes migration to new versions less risky.
Removing GDT_Byte would have enormous breaking implications! Signed Byte
is I believe a marginal feature not commonly used by GDAL based
applications, partly because the support for it before RFC87 was clunky
and partial.
Even
http://www.spatialys.com
