[gdal-dev] gdal_merge
Even Rouault even.rouault at spatialys.com
Tue Nov 29 12:10:22 PST 2022
Clive,
CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE is a configuration option /
environment variable, so you have to pass it with --config
CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE YES
Even
Le 29/11/2022 à 20:12, Clive Swan a écrit :
> Greetings,
> I am trying to select band 1 and then use gdal_merge to merge two tiff
> files in an AWS bucket.
> Getting odd errors.
> gdal_merge.py -o
> /vsis3/summer-outputs/3_dataupdated/rcp26-2020-coastal_flood-NA-false.tif
> /vsis3/summer-outputs/3_data_ready_for_spectra/coastal-undefended-rcp26-2020.tif
>  /vsis3/summer-outputs/5_UK_prod_rasters/coastal-undefended-rcp26-2020.tif
>  -of GTiff  -co -b 1  -co CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE=YES
> -co NUM_THREADS=ALL_CPUS --config AWS_ACCESS_KEY_ID KEY_ID --config
> AWS_SECRET_ACCESS_KEY ACCESS_KEY
> ERRORS
>   `1' not recognized as a supported file format. << band 1
> Warning 6: creation option '-b' is not formatted with the key=value
> format << band 1
> Warning 6: *driver GTiff does not support creation option
> *CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE << Get an error if leave this out
> ERROR 1: *w+ not supported for /vsis3, unless*
> CPL_VSIL_USE_TEMP_FILE_FOR_RANDOM_WRITE is set to YES             <<
> Get an error
> ERROR 4: Attempt to create new tiff file
> `/vsis3/summer-outputs/3_data_ready/updated/rcp26-2020-coastal_flood-NA-false.tif'
> failed: *Permission denied  << *added the security key, etc
> *Creation failed, terminating gdal_merge.*
>  Regards,
> Clive Swan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221129/d860bb9a/attachment.htm>
