[gdal-dev] PostGIS and ogrinfo: not able to view all the tables of a PostGIS schema
andy aborruso at gmail.com
Wed Nov 30 04:00:10 PST 2022
if I run
ogrinfo -ro -so PG:"dbname='arpa_db' host='192.168.xxx.xxx' port='5432'
user='postgres' password='xxxx' schemas=public"
I see 3 tables in the list. The real list contains 32 tables.
If I explore the same schema, with the same credentials, using pgAdmin 4 I
see all 32 tables.
If I run ogrinfo pointing to a table that ogr does not see, I read the info
of that table.
What am I doing wrong using OGR? Why does it not list all 32 tables?
Thank you
___________________
Andrea Borruso
website: https://medium.com/tantotanto
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
___________________
"cercare e saper riconoscere chi e cosa,
 in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221130/8958dfaa/attachment.htm>
