[gdal-dev] PostGIS and ogrinfo: not able to view all the tables of a PostGIS schema
Even Rouault even.rouault at spatialys.com
Wed Nov 30 04:53:56 PST 2022
try adding -oo LIST_ALL_TABLES=YES
cf https://gdal.org/drivers/vector/pg.html#dataset-open-options
Le 30/11/2022 à 13:00, andy a écrit :
> Hi,
> if I run
> ogrinfo -ro -so PG:"dbname='arpa_db' host='192.168.xxx.xxx'
> port='5432' user='postgres' password='xxxx' schemas=public"
> I see 3 tables in the list. The real list contains 32 tables.
> If I explore the same schema, with the same credentials, using pgAdmin
> 4 I see all 32 tables.
> If I run ogrinfo pointing to a table that ogr does not see, I read the
> info of that table.
> What am I doing wrong using OGR? Why does it not list all 32 tables?
> Thank you
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
>  in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20221130/11863c4f/attachment.htm>
