[gdal-dev] ogr2ogr postgis to sqlite composite primary key issueissue
Scott public at postholer.com
Tue Aug 15 17:57:05 PDT 2023
You could build your column list without that specific column and pass
it to ogr2ogr (bash):
ogr2ogr -sql "select $(psql -d mydb --pset='footer=off' -F',' -qAc
"select * from table where false" |sed 's/columnToOmit,//g') from table"
target.gpkg PG:dbname=mydb
On 8/15/23 17:12, Brent Wood via gdal-dev wrote:
> Hi,
> I'm looking to use ogr2ogr to replicate a Postgis schema into a
> Spatialite database. (Make a snapshot copy of institutional tables on a
> field laptop with possible no internet access)
> I have a script to identify the relevant tables and invoke ogr2ogr to
> copy each table.
> Some of the source (Postgis) tables have a composite primary key.
> ogr2ogr flags these and says such keys are unsupported. It fails to copy
> these tables.
> What I'd like it to do is copy the data in such cases but ignore the
> primary key.
> Is this possible?
> Thanks,
> Brent Wood
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
