[gdal-dev] ogr2ogr postgis to sqlite composite primary key issueissue
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Tue Aug 15 23:37:30 PDT 2023
Could you share some test data? A "CREATE TABLE..." SQL and an INSERT for one row should be enough. Use minimal number or fields for keeping it simple.
-Jukka Rahkonen-
Lähettäjä: gdal-dev <gdal-dev-bounces at lists.osgeo.org> Puolesta Brent Wood via gdal-dev
Lähetetty: keskiviikko 16. elokuuta 2023 4.27
Vastaanottaja: gdal-dev at lists.osgeo.org; Scott <public at postholer.com>
Aihe: Re: [gdal-dev] ogr2ogr postgis to sqlite composite primary key issueissue
Thanks,
The primary key on the source tables is on required columns - it is a natural key based on core data so cannot be excluded to have a meaningful dataset exported.
Also, invoking it your way provides a data only export - just the output of a select statement. I'm trying to create replicate data structures populated with the data in the Spatialite database.
It seems that using an intermediate format such as shapefile should work, as this will essentially drop any primasry key anyway, but I'm trying the direct approach first.
Also, your example exports to geopackage, that is not what I'm after, Spatialite is much more than geopackage.
Cheers
Brent
On Wednesday, August 16, 2023 at 12:57:14 PM GMT+12, Scott <public at postholer.com<mailto:public at postholer.com>> wrote:
You could build your column list without that specific column and pass
it to ogr2ogr (bash):
ogr2ogr -sql "select $(psql -d mydb --pset='footer=off' -F',' -qAc
"select * from table where false" |sed 's/columnToOmit,//g') from table"
target.gpkg PG:dbname=mydb
On 8/15/23 17:12, Brent Wood via gdal-dev wrote:
> Hi,
> I'm looking to use ogr2ogr to replicate a Postgis schema into a
> Spatialite database. (Make a snapshot copy of institutional tables on a
> field laptop with possible no internet access)
> I have a script to identify the relevant tables and invoke ogr2ogr to
> copy each table.
> Some of the source (Postgis) tables have a composite primary key.
> ogr2ogr flags these and says such keys are unsupported. It fails to copy
> these tables.
> What I'd like it to do is copy the data in such cases but ignore the
> primary key.
> Is this possible?
> Thanks,
> Brent Wood
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230816/2607a187/attachment-0001.htm>
