[gdal-dev] Inconsistencies in WKT CRS representations
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Aug 16 09:50:24 PDT 2023
https://crs-explorer.proj.org/ is using pyproj to generate all the
information, based on the last version of PROJ
In particular, your CRS is here:
https://crs-explorer.proj.org/?searchText=102022&ignoreWorld=false&allowDeprecated=false&authorities=EPSG,ESRI&activeTypes=PROJECTED_CRS
You have links to WKT1 and 2
Cheers,
Javier
On Wed, 16 Aug 2023 at 18:08, Howard Butler <howard at hobu.co> wrote:
> > On Aug 16, 2023, at 10:59 AM, Small, Jennifer L. (GSFC-618.0)[SCIENCE
> SYSTEMS AND APPLICATIONS INC] via gdal-dev <gdal-dev at lists.osgeo.org>
> wrote:
> > Is it best to represent the CRS with WKT rather than importing using
> SetFromUserInput with EPSG:code or ESRI:code? If so, what source has the
> definitive WKT, spatialreference.org or epsg.io?
> IMO, the definitive definition is 'projinfo'
> > projinfo ESRI:102022
> spatialreference.org has not been updated in many years and should be
> considered out of date. I don't know what version of PROJ epsg.io is
> running. https://epsg.org/ runs GDAL/PROJ too, but I don't know which
> version, and of course that isn't going to respond to ESRI codes.
> Hope this helps,
> Howard
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230816/2dd16199/attachment.htm>
