[gdal-dev] Is SQLITE dialect supported on Memory OGR datasets?
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] jesse.r.meyer at nasa.gov
Mon Aug 21 12:30:22 PDT 2023
This works:
tc_lyr = execute_SQL(tree_canopy_mem_ds, "select * from trees", spatialFilter=c_geo)
However, this:
tc_lyr = execute_SQL(tree_canopy_mem_ds, "select * from trees", spatialFilter=c_geo, dialect="SQLITE")
Returns:
In Initialize(): sqlite3_step(SELECT _rowid_, * FROM 'trees' LIMIT 1): SQL logic error
Where execute_SQL = ogr.DataSource.ExecuteSQL
Which is naturally a surprise given that I’m not explicitly asking for the rowid, nor to limit the number of returned rows.
The docs claim that the SQLite dialect can be used with any OGR datasource, so I did expect this to work.  The input datasource is GeoPackage, which is based on SQLite, so I assume my install is built with SQLite, though I’d welcome advice on how to explicitly demonstrate this.
My GDAL version install is 3.6.4, on OSX 13.5.
Thanks,
Jesse
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230821/43824e52/attachment.htm>
