[gdal-dev] [EXTERNAL] [BULK] Is SQLITE dialect supported on Memory OGR datasets?
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] jesse.r.meyer at nasa.gov
Mon Aug 21 13:39:38 PDT 2023
For clarity, the input datasource to THIS method is a memory datasource.  But the source of that datasource was a geopackage (via CopyDataSource).
Best,
Jesse
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of "Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev" <gdal-dev at lists.osgeo.org>
Reply-To: "Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC]" <jesse.r.meyer at nasa.gov>
Date: Monday, August 21, 2023 at 3:30 PM
To: "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] [BULK] [gdal-dev] Is SQLITE dialect supported on Memory OGR datasets?
This works:
tc_lyr = execute_SQL(tree_canopy_mem_ds, "select * from trees", spatialFilter=c_geo)
However, this:
tc_lyr = execute_SQL(tree_canopy_mem_ds, "select * from trees", spatialFilter=c_geo, dialect="SQLITE")
Returns:
In Initialize(): sqlite3_step(SELECT _rowid_, * FROM 'trees' LIMIT 1): SQL logic error
Where execute_SQL = ogr.DataSource.ExecuteSQL
Which is naturally a surprise given that I’m not explicitly asking for the rowid, nor to limit the number of returned rows.
The docs claim that the SQLite dialect can be used with any OGR datasource, so I did expect this to work.  The input datasource is GeoPackage, which is based on SQLite, so I assume my install is built with SQLite, though I’d welcome advice on how to explicitly demonstrate this.
My GDAL version install is 3.6.4, on OSX 13.5.
Thanks,
Jesse
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230821/5f10c7ed/attachment-0001.htm>
