[gdal-dev] Is SQLITE dialect supported on Memory OGR datasets?
Even Rouault even.rouault at spatialys.com
Mon Aug 21 15:22:30 PDT 2023
Jesse,
No it wasn't. Fix in https://github.com/OSGeo/gdal/pull/8247
Potential workaround: use a in-memory SQLite or GeoPackage with a
/vsimem/ filename
Even
Le 21/08/2023 à 21:30, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND
APPLICATIONS INC] via gdal-dev a écrit :
> Hi,
> This works:
> tc_lyr =execute_SQL(tree_canopy_mem_ds,"select * from
> trees",/spatialFilter/=c_geo)
> However, this:
> trees",/spatialFilter/=c_geo,/dialect/="SQLITE")
> Returns:
> In Initialize(): sqlite3_step(SELECT _rowid_, * FROM 'trees' LIMIT 1):
> SQL logic error
> Where execute_SQL = ogr.DataSource.ExecuteSQL
> Which is naturally a surprise given that I’m not explicitly asking for
> the rowid, nor to limit the number of returned rows.
> The docs claim that the SQLite dialect can be used with any OGR
> datasource, so I did expect this to work.  The input datasource is
> GeoPackage, which is based on SQLite, so I assume my install is built
> with SQLite, though I’d welcome advice on how to explicitly
> demonstrate this.
> My GDAL version install is 3.6.4, on OSX 13.5.
> Thanks,
> Jesse
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230822/bee799cd/attachment.htm>
