[gdal-dev] [EXTERNAL] Re: Is SQLITE dialect supported on Memory OGR datasets?
Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] jesse.r.meyer at nasa.gov
Tue Aug 22 07:11:09 PDT 2023
As per your workaround suggestion,
Are these intended to work?  The returned datasource is None.  Removing the `/vsimem` preamble returns the disk-backed geopackage datasource as expected.
tree_canopy_mem_ds = ogr.Open('/vsimem/Users/jrmeyer3/Downloads/features.gpkg')
tree_canopy_mem_ds = ogr.GetDriverByName("GPKG").Open('/vsimem/Users/jrmeyer3/Downloads/features.gpkg')
Date: Monday, August 21, 2023 at 6:22 PM
To: "Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC]" <jesse.r.meyer at nasa.gov>, "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
Subject: [EXTERNAL] Re: [gdal-dev] Is SQLITE dialect supported on Memory OGR datasets?
CAUTION: This email originated from outside of NASA.  Please take care when clicking links or opening attachments.  Use the "Report Message" button to report suspicious messages to the NASA SOC.
Jesse,
No it wasn't. Fix in https://github.com/OSGeo/gdal/pull/8247
Potential workaround: use a in-memory SQLite or GeoPackage with a /vsimem/ filename
Even
Le 21/08/2023 à 21:30, Meyer, Jesse R. (GSFC-618.0)[SCIENCE SYSTEMS AND APPLICATIONS INC] via gdal-dev a écrit :
This works:
tc_lyr = execute_SQL(tree_canopy_mem_ds, "select * from trees", spatialFilter=c_geo)
However, this:
tc_lyr = execute_SQL(tree_canopy_mem_ds, "select * from trees", spatialFilter=c_geo, dialect="SQLITE")
Returns:
In Initialize(): sqlite3_step(SELECT _rowid_, * FROM 'trees' LIMIT 1): SQL logic error
Where execute_SQL = ogr.DataSource.ExecuteSQL
Which is naturally a surprise given that I’m not explicitly asking for the rowid, nor to limit the number of returned rows.
The docs claim that the SQLite dialect can be used with any OGR datasource, so I did expect this to work.  The input datasource is GeoPackage, which is based on SQLite, so I assume my install is built with SQLite, though I’d welcome advice on how to explicitly demonstrate this.
My GDAL version install is 3.6.4, on OSX 13.5.
Thanks,
Jesse
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com<http://www.spatialys.com/>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230822/7c64b5b6/attachment-0001.htm>
