[gdal-dev] Setting TIFFTAG_* in COG
Javier Jimenez Shaw j1 at jimenezshaw.com
Mon Dec 4 07:14:40 PST 2023
Hi
I am trying to convert a "normal" tiff file into a COG. For that I am using
an intermediate vrt file to add the geolocation parameters, and finally
copy the vrt into a COG.
I am doing it in C++, but it should be similar doing it on the command line
I hope. (In some cases I am using also other parameters of the
gdalbuildvrt).
My problem is how are the "magic words" to set the TIFFTAG_* (like
TIFFTAG_DATETIME) in the final COG. I guess I could use the option "-oo"
for the options in GDALBuildVRT, or in the options of the method
"CreateCopy" for COG driver.
Is that doable that way? Should I prefix "TIFFTAG_..." with something like
"GDALMETADATA:"? (I tried, unsuccessfully)
Is that the same for AREA_OR_POINT?
Thanks.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231204/3e343d20/attachment.htm>
