[gdal-dev] Requiring numpy for the Python bindings
Daniel Evans daniel.fred.evans at gmail.com
Mon Dec 4 14:51:38 PST 2023
Agree with Kurt - it's always struck me as a little surprising that it was
optional. There's also not very much of a Python stack you can build that
involves GDAL but doesn't pull in Numpy through another dependency, as Even
said.
I would've thought that in any constrained environment where GDAL is
required, but Numpy is too much of a overhead, that using Python would be a
somewhat unusual choice to go with over the many other bindings that GDAL
offers.
Cheers,
Daniel
On Mon, 4 Dec 2023, 18:50 Kurt Schwehr via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> I lean towards just requiring numpy. It's super common and once a system
> brings in gdal python, it can't be a super constrained env where keeping
> things really small is critical. Just requiring numpy simplifies a number
> of aspects.
> I think the setup.py topic as a whole is somewhat separate.l.  So
> whichever way the numpy dep goes (required or optional), switching to
> pyproject.toml seems important. I'm fairly new to pyproject.toml, so I
> might be missing something.
> -Kurt
> On Mon, Dec 4, 2023 at 10:38 AM Even Rouault via gdal-dev <
>> Hi,
>> The current situation where numpy is an optional dependency of the GDAL
>> Python bindings is quite cumbersome to deal with our setup.py's
>> setuptools . All details (a bit tricky) in
>> https://github.com/OSGeo/gdal/issues/8069 . It seems it would be simpler
>> if the bindings just required numpy, which is the confugration most
>> people using the bindings likely actually end up using anyway.
>> Any opposition to that?
>> Even
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231204/b6aa71a4/attachment.htm>
