[gdal-dev] MVT tileset with limited output extent
Even Rouault even.rouault at spatialys.com
Tue Dec 5 06:05:53 PST 2023
You can use the -spat + (-clipsrc or -clipdst) switches of ogr2ogr
Le 05/12/2023 à 14:57, Jan Wolski via gdal-dev a écrit :
> Hi,
> I'm creating MVT tilesets for the ETRS-TM35FIN tiling scheme using
> GDAL/OGR. I'm prototyping with ogr2ogr but later I will be using
> Python bindings to create the production workflow.
> Is there a way to limit the geographic extent of where the MVT driver
> creates tiles? By default it seems to create all tiles that intersect
> any input feature. I would like to create only tiles that intersect a
> given extent. This is to enable partial update of a MVT tileset.
> This is the ogr2ogr command I have now:
> ogr2ogr -f MVT stand MV_R5232B.gpkg stand -dsco "MAXZOOM=11" -dsco
> "MINZOOM=8" -dsco "TILE_EXTENSION=mvt" -dsco
> "TILING_SCHEME=EPSG:3067,-548576,8388608,2097152" -dsco "TYPE=overlay"
> -dsco "COMPRESS=NO"
> Thanks,
> Jan Wolski
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231205/e9fc6cf3/attachment.htm>
