[gdal-dev] MVT tileset with limited output extent
Jan Wolski jan.wolski at trimble.com
Wed Dec 20 07:06:50 PST 2023
Thanks for the reply.
I can see how spatially filtering the input (-spat) is useful, but I don't
want to clip the geometries (other than clipping by tile edges that MVT
driver does by default). What I'm after is spatial filtering of the output
tiles based on each tile extent.
So to further clarify, I could do the translation using -spat <ROI> and
then iterate over all of the generated MVT files and delete the ones whose
tile extent does not intersect with <ROI>. But that would waste resources
in a big way.
Thanks,
Jan Wolski
On Tue, Dec 5, 2023 at 4:05 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> You can use the -spat + (-clipsrc or -clipdst) switches of ogr2ogr
> Le 05/12/2023 à 14:57, Jan Wolski via gdal-dev a écrit :
> Hi,
> I'm creating MVT tilesets for the ETRS-TM35FIN tiling scheme using
> GDAL/OGR. I'm prototyping with ogr2ogr but later I will be using Python
> bindings to create the production workflow.
> Is there a way to limit the geographic extent of where the MVT driver
> creates tiles? By default it seems to create all tiles that intersect any
> input feature. I would like to create only tiles that intersect a given
> extent. This is to enable partial update of a MVT tileset.
> This is the ogr2ogr command I have now:
> ogr2ogr -f MVT stand MV_R5232B.gpkg stand -dsco "MAXZOOM=11" -dsco
> "MINZOOM=8" -dsco "TILE_EXTENSION=mvt" -dsco
> "TILING_SCHEME=EPSG:3067,-548576,8388608,2097152" -dsco "TYPE=overlay"
> -dsco "COMPRESS=NO"
> Thanks,
> Jan Wolski
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231220/369fef6d/attachment.htm>
