[gdal-dev] Virtual File Systems s3 not working
zs s cmulershen at gmail.com
Wed Dec 6 21:09:57 PST 2023
When I use the following command, I get an error.
command:
ogrinfo --config AWS_ACCESS_KEY_ID "XXX" --config AWS_SECRET_ACCESS_KEY
"XXX" --config AWS_S3_ENDPOINT XXX --config AWS_HTTPS NO --config
AWS_VIRTUAL_HOSTING FALSE /vsizip//viss3//oss20/test.shp.zip
error message:
ogrinfo failed - unable to open '/vsizip//viss3//oss20/test.shp.zip'
It runs fine locally, is there any way to troubleshoot the problem? Is it
related to the operating system? We are using a less common linux
distribution.
thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231207/f9b230ba/attachment.htm>
