[gdal-dev] Virtual File Systems s3 not working
zs s cmulershen at gmail.com
Wed Dec 6 21:12:12 PST 2023
The path is /vsizip//vsis3//oss20/test.shp.zip, sorry, it's typo, but it's
still not work
zs s <cmulershen at gmail.com> 于2023年12月7日周四 13:09写道:
> Hi,
> When I use the following command, I get an error.
> command:
> ogrinfo --config AWS_ACCESS_KEY_ID "XXX" --config AWS_SECRET_ACCESS_KEY
> "XXX" --config AWS_S3_ENDPOINT XXX --config AWS_HTTPS NO --config
> AWS_VIRTUAL_HOSTING FALSE /vsizip//viss3//oss20/test.shp.zip
> error message:
> ogrinfo failed - unable to open '/vsizip//viss3//oss20/test.shp.zip'
> It runs fine locally, is there any way to troubleshoot the problem? Is it
> related to the operating system? We are using a less common linux
> distribution.
> thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231207/08433b4e/attachment.htm>
