[gdal-dev] GTiff bit shuffle compression feature request
Even Rouault even.rouault at spatialys.com
Fri Dec 8 11:32:50 PST 2023
Le 08/12/2023 à 20:23, Laurențiu Nicola via gdal-dev a écrit :
> On Fri, Dec 8, 2023, at 21:11, Even Rouault wrote:
>>>  - GeoTIFF DEFLATE 280 MB
>> Is it with PREDICTOR=3 ?  (If not, then the ZARR datasets should also
>> be compressed with FILTER=DELTA to have a fair comparison)
> I would expect a fair comparison to be between PREDICTOR=3 and
> FILTER=DELTA and not the other way around,
yes, poor wording of mine. I meant that if using PREDICTOR=3, one should
compare with FILTER=DELTA. But looking more closely, they are not
strictly equivalent. PREDICTOR=3 applies the delta as b[0]-a[0],
b[1]-a[1], b[2]-a[2], b[3]-a[3] where a[0...3] and b[0...3] are seen as
the 4 byte representation of the float32, whereas FILTER=DELTA does the
difference b_float - a_float as floating point. This isn't the same...
> but it does seem to level the field significantly:
>  - GeoTIFF DEFLATE PREDICTOR=3 255 MB
>  - Zarr DELTA BLOSC zlib NONE 290 MB
>  - Zarr DELTA BLOSC zlib BIT 266 MB
>  - Zarr DELTA BLOSC zlib BYTE 259 MB
>>>  - Zarr BLOSC zlib NONE 281 MB
>>>  - Zarr BLOSC zlib BIT 253 MB
>>>  - Zarr BLOSC zlib BYTE 249 MB
> So FILTER=DELTA yields worse compression, while GeoTIFF PREDICTOR=3
> does very well. No need for Zarr! I don't remember PREDICTOR=3 doing
> so well in the past, so.. no idea :-).
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231208/d5d2da89/attachment.htm>
