[gdal-dev] GTiff bit shuffle compression feature request
Laurențiu Nicola lnicola at dend.ro
Fri Dec 8 12:00:59 PST 2023
On Fri, Dec 8, 2023, at 21:32, Even Rouault wrote:
> yes, poor wording of mine. I meant that if using PREDICTOR=3, one should compare with FILTER=DELTA. But looking more closely, they are not strictly equivalent. PREDICTOR=3 applies the delta as b[0]-a[0], b[1]-a[1], b[2]-a[2], b[3]-a[3] where a[0...3] and b[0...3] are seen as the 4 byte representation of the float32, whereas FILTER=DELTA does the difference b_float - a_float as floating point. This isn't the same...
https://www.blosc.org/posts/bytedelta-enhance-compression-toolset/ seems to be the equivalent.
> inode allocation
XFS or ZIP?
> extra step to decompress Zarr out of ZIP
Most libraries should be able to read Zarr directly from a ZIP archive.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231208/73625383/attachment-0001.htm>
