[gdal-dev] Un-vendoring a number of third-party libraries?
Sebastiaan Couwenberg sebastic at xs4all.nl
Fri Dec 15 06:49:01 PST 2023
On 12/15/23 15:35, Even Rouault via gdal-dev wrote:
> Thoughts ? (given the length of the email, it should probably be
> formalized as a RFC. I'll do that, unless there is a massive uprising
> against the proposal...)
LERC doesn't support big endian architectures currently, only using that
on little endian architectures using the internal copy currently works
as expected. Using the external library would require conditionals in
the packaging which I'm not in favor of.
Kind Regards,
Bas
  GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
