[gdal-dev] Trouble building 3.8.2 from source
Even Rouault even.rouault at spatialys.com
Tue Dec 26 14:45:24 PST 2023
Barry,
> This probably has a simple explanation.
> I have downloaded the 3.8.2 source code.
> In the local source code directory I make a build dir and cd into it.
Are you sure you didn't do an initial build in the top directory ?
Because there's no port/cpl_config.h in the tarball, so the only way to
have one there I can imagine is that there was an initial build from the
top directory. Just try to remove port/cpl_config.h and things should
work fine
Even
http://www.spatialys.com
