[gdal-dev] Trouble building 3.8.2 from source
Barry DeZonia bdezonia at gmail.com
Tue Dec 26 14:59:09 PST 2023
Thanks for the pointer. That was the problem. I just extracted the source
again elsewhere and can build there fine.
On Tue, Dec 26, 2023 at 4:45 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> Barry,
> > This probably has a simple explanation.
> > I have downloaded the 3.8.2 source code.
> > In the local source code directory I make a build dir and cd into it.
> Are you sure you didn't do an initial build in the top directory ?
> Because there's no port/cpl_config.h in the tarball, so the only way to
> have one there I can imagine is that there was an initial build from the
> top directory. Just try to remove port/cpl_config.h and things should
> work fine
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231226/b1ddafcb/attachment.htm>
