[gdal-dev] Java API
Barry DeZonia bdezonia at gmail.com
Thu Dec 28 18:15:37 PST 2023
Hey all,
I just wanted to let you know I updated my java code that uses GDAL (and
it's Java API) to load data from MDArray supporting drivers. My initial
tests (using my zorbage-viewer app to call zorbage-gdal routines) shows the
MDArray Java code is working well. Data files are a bit slow to load but
otherwise no complaints.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20231228/7cee8b7a/attachment.htm>
