[gdal-dev] why padfExtent/s in gdal_alg.h ?
Thomas Knudsen knudsen.thomas at gmail.com
Wed Feb 8 02:42:14 PST 2023
>  Ah ok, mostly I was just confused why it's not an error for the compiler
The compiler only needs to know the type of the argument - in a header
file, the identifier name following
the type is for human information only
Den ons. 8. feb. 2023 kl. 00.49 skrev Michael Sumner <mdsumner at gmail.com>:
> On Wed, Feb 8, 2023 at 10:44 AM Even Rouault <even.rouault at spatialys.com>
> wrote:
>> Michael,
>> Feel free to submit a fix as there's obviously no justification for the
>> discrepancy other than just being accidental.
> ... but I'm getting used to surprises learning C++ :)
> PR incoming, thanks!
> Cheers, Mike
>> There are likely hundreds of similar occurrences in the code base.  I
>> believe there's a compiler warning (or at least cppcheck) to detect this,
>> but it is not activated.
>> Even
>> Le 08/02/2023 à 00:35, Michael Sumner a écrit :
>> This is not causing any problems afaict, but I happened to notice the
>> plural for 'padfExtents' in the gdal_alg.h signature for
>> GDALSuggestedWarpOutput2 compared to gdaltransformer.cpp
>> https://github.com/OSGeo/gdal/blob/579693c2975cda414af75239e09b8b7b952029ca/alg/gdal_alg.h#L264
>> https://github.com/OSGeo/gdal/blob/579693c2975cda414af75239e09b8b7b952029ca/alg/gdaltransformer.cpp#L412
>> The discrepancy is visible in the doc here:
>> https://gdal.org/api/gdal_alg.html#_CPPv424GDALSuggestedWarpOutput212GDALDatasetH19GDALTransformerFuncPvPdPiPiPdi
>> Cheers, Mike
>> Michael Sumner
>> Software and Database Engineer
>> Australian Antarctic Division
>> Hobart, Australia
>> e-mail: mdsumner at gmail.com
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
>> -- http://www.spatialys.com
>> My software is free, but my time generally not.
> Michael Sumner
> Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/b37abd6c/attachment-0001.htm>
