[gdal-dev] why padfExtent/s in gdal_alg.h ?
Michael Sumner mdsumner at gmail.com
Tue Feb 7 15:47:37 PST 2023
On Wed, Feb 8, 2023 at 10:44 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Michael,
> Feel free to submit a fix as there's obviously no justification for the
> discrepancy other than just being accidental.
Ah ok, mostly I was just confused why it's not an error for the compiler
... but I'm getting used to surprises learning C++ :)
PR incoming, thanks!
Cheers, Mike
> There are likely hundreds of similar occurrences in the code base.  I
> believe there's a compiler warning (or at least cppcheck) to detect this,
> but it is not activated.
> Even
> Le 08/02/2023 à 00:35, Michael Sumner a écrit :
> This is not causing any problems afaict, but I happened to notice the
> plural for 'padfExtents' in the gdal_alg.h signature for
> GDALSuggestedWarpOutput2 compared to gdaltransformer.cpp
> https://github.com/OSGeo/gdal/blob/579693c2975cda414af75239e09b8b7b952029ca/alg/gdal_alg.h#L264
> https://github.com/OSGeo/gdal/blob/579693c2975cda414af75239e09b8b7b952029ca/alg/gdaltransformer.cpp#L412
> The discrepancy is visible in the doc here:
> https://gdal.org/api/gdal_alg.html#_CPPv424GDALSuggestedWarpOutput212GDALDatasetH19GDALTransformerFuncPvPdPiPiPdi
> Cheers, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
Michael Sumner
Hobart, Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/6f6f4876/attachment.htm>
