[gdal-dev] why padfExtent/s in gdal_alg.h ?
Even Rouault even.rouault at spatialys.com
Tue Feb 7 15:44:44 PST 2023
Michael,
Feel free to submit a fix as there's obviously no justification for the
discrepancy other than just being accidental.
There are likely hundreds of similar occurrences in the code base.  I
believe there's a compiler warning (or at least cppcheck) to detect
this, but it is not activated.
Even
Le 08/02/2023 à 00:35, Michael Sumner a écrit :
> This is not causing any problems afaict, but I happened to notice the
> plural for 'padfExtents' in the gdal_alg.h signature for
> GDALSuggestedWarpOutput2 compared to gdaltransformer.cpp
> https://github.com/OSGeo/gdal/blob/579693c2975cda414af75239e09b8b7b952029ca/alg/gdal_alg.h#L264
> https://github.com/OSGeo/gdal/blob/579693c2975cda414af75239e09b8b7b952029ca/alg/gdaltransformer.cpp#L412
> The discrepancy is visible in the doc here:
> https://gdal.org/api/gdal_alg.html#_CPPv424GDALSuggestedWarpOutput212GDALDatasetH19GDALTransformerFuncPvPdPiPiPdi
> Cheers, Mike
> Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/e7de0a0b/attachment.htm>
