[gdal-dev] AWS Lambda layer with GDAL python bindings
Ari Jolma ari.jolma at gmail.com
Wed Feb 8 07:44:54 PST 2023
On that page there are a number of arns for lambda layers, but when I
try to get the http location of those I get from
aws lambda get-layer-version-by-arn --arn
arn:aws:lambda:us-east-1:552188055668:layer:geolambda-python:3 --query
Content.Location --output text
An error occurred (AccessDeniedException) when calling the
GetLayerVersionByArn operation: User: <removed> is not authorized to
perform: lambda:GetLayerVersion on resource:
arn:aws:lambda:us-east-1:552188055668:layer:geolambda-python:3 because
no resource-based policy allows the lambda:GetLayerVersion action
And I have an admin access to one AWS account.
How do I get those layers?
Ari
Joe Lee kirjoitti 8.2.2023 klo 16.35:
> This worked quite well in 2019 with a few hacks:
> https://github.com/developmentseed/geolambda
> *From: *gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Ari
> Jolma <ari.jolma at gmail.com>
> *Date: *Wednesday, February 8, 2023 at 1:42 AM
> *To: *gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
> *Subject: *[gdal-dev] AWS Lambda layer with GDAL python bindings
> Hi,
> I need an AWS Lambda layer with GDAL python bindings, for "from osgeo
> import gdal", but it seems difficult to make such a layer.
> In fact all I need is gdal.Open and gdal.BuildVRT - I have not dug
> deeper into rasterio, can it do those?
> Anyway, I installed GDAL on a machine with python 3.8 as that's what to
> lambda runtime will be, and from there copied files to a zip with /lib
> and /python. The /lib is for the shared objects. I have now 94 libraries
> there. The error I now get from
> try
>      from osgeo import gdal
> except
> in the lambda is
> ImportError: /lib64/libm.so.6: version `GLIBC_2.27' not found (required
> by /opt/lib/libgdal.so.29)
> this seems to be a problem as that's the lambda's libm and not the libm
> in /lib, which I assume should work.
> Anybody know a solution? I tried some recipes I found from the net howto
> build such a layer but they did not work for me out of the box, so I
> tried myself.
> Best,
> Ari
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/b69d8921/attachment.htm>
