[gdal-dev] AWS Lambda layer with GDAL python bindings
Ari Jolma ari.jolma at gmail.com
Wed Feb 8 10:04:05 PST 2023
Could not let this go without a last try.
I finally managed to create a working lambda layer using the Dockerfile
from https://github.com/developmentseed/geolambda as a starting point
and with a more than a few hacks got GDAL to compile within the docker
and then compile the swig bindings and then create a working layer zip
using the package.sh from within the docker image as a starting point.
Thanks for the help!
Best,
Ari
Vincent Sarago kirjoitti 8.2.2023 klo 16.37:
> Sharing what I sent to Ari directly (forgot to anser to all)
> Hi Ari,
> You can have a look at https://github.com/lambgeo/docker-lambda
> It doesn’t provide any python bindings but if you follow
> https://github.com/lambgeo/docker-lambda#2-advanced-need-other-dependencies you
> can create a lambda package with all the deps you need.
> Vincent
>> On Feb 8, 2023, at 3:35 PM, Joe Lee <hyoklee at hdfgroup.org> wrote:
>> This worked quite well in 2019 with a few hacks:
>> *From:*gdal-dev <gdal-dev-bounces at lists.osgeo.org> on behalf of Ari
>> Jolma <ari.jolma at gmail.com>
>> *Date:*Wednesday, February 8, 2023 at 1:42 AM
>> *To:*gdal-dev at lists.osgeo.org<gdal-dev at lists.osgeo.org>
>> *Subject:*[gdal-dev] AWS Lambda layer with GDAL python bindings
>> Hi,
>> I need an AWS Lambda layer with GDAL python bindings, for "from osgeo
>> import gdal", but it seems difficult to make such a layer.
>> In fact all I need is gdal.Open and gdal.BuildVRT - I have not dug
>> deeper into rasterio, can it do those?
>> Anyway, I installed GDAL on a machine with python 3.8 as that's what to
>> lambda runtime will be, and from there copied files to a zip with /lib
>> and /python. The /lib is for the shared objects. I have now 94 libraries
>> there. The error I now get from
>> try
>>      from osgeo import gdal
>> except
>> in the lambda is
>> ImportError: /lib64/libm.so.6: version `GLIBC_2.27' not found (required
>> by /opt/lib/libgdal.so.29)
>> this seems to be a problem as that's the lambda's libm and not the libm
>> in /lib, which I assume should work.
>> Anybody know a solution? I tried some recipes I found from the net howto
>> build such a layer but they did not work for me out of the box, so I
>> tried myself.
>> Best,
>> Ari
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230208/63c327de/attachment-0001.htm>
