[gdal-dev] OpenJPEG JPEG2000 Driver
Simon Eves simon.eves at heavy.ai
Tue Feb 14 16:33:48 PST 2023
I recreated the compile/link test that *configure* is doing, and it also
fails outside.
I then determined I could make it work by also adding *-lm* and *-lpthread*
to the link.
I hacked GDAL *configure* script to also add those two to *$LIBS* when it
does the OpenJPEG link test, and now that passes, and then *configure*
reports OpenJPEG is enabled.
However, when I then compile GDAL, it fails in the final huge link of
*libgdal.la
<http://libgdal.la>* with
*/usr/bin/ld: /usr/local/mapd-deps/lib/libopenjp2.a(cio.c.o): relocation
R_X86_64_PC32 against symbol `opj_stream_write_skip' can not be used when
making a shared object; recompile with -fPIC/usr/bin/ld: final link failed:
bad value*
I assume this is because it's trying to make a shared GDAL lib, but
including the static OpenJPEG lib.
I tried adding * -DCMAKE_CPP_FLAGS="-fPIC" -DCMAKE_CXX_FLAGS="-fPIC"* to
the OpenJPEG build CMake invocation, but that made no difference.
Any help with this would be greatly appreciated, as we're code-freezing end
of this week and I'd really like to get this in.
On Sun, Feb 12, 2023 at 6:44 PM Simon Eves <simon.eves at heavy.ai> wrote:
> Is there some trick to enabling this driver with the old non-CMake build
> env...? :)
> I am building OpenJPEG 2.5.0 (from source) and it's building and
> installing fine into the same include/lib tree as everything else, and then
> GDAL configure (just adding *--with-openjpeg*, no path, right?) sees it
> and tests it, but the compile test of *opj_setup_decoder()* apparently
> fails, so *HAVE_OPENJPEG* gets disabled again.
> I see that function in *openjpeg.h* and (with *nm*) in *libopenjp2.a*, so
> I'm not sure why it's failing.
> I tried some other CMake option variations for OpenJPEG but nothing fixed
> it.
> Ubuntu 20.04, GCC 9.4, GDAL 3.4.1, all-static build
> I have tried GDAL 3.6.2 (and PROJ 9.2.1) building them with CMake and I
> think the OpenJPEG part is working, then but our dependencies build falls
> over later with something else that doesn't like the newer PROJ, and I'd
> rather not bump the GDAL & PROJ and data files versions at this time
> anyway, as we're very close to a release.
> I just wanna minimally add JPEG2000 to what we have...
> TIA
> Simon Eves
> Senior Rendering Engineer
> +1 (415) 902-1996
> <http://www.heavy.ai>
> (formerly OmniSci)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230214/57e78d95/attachment.htm>
