[gdal-dev] Error when trying to build Docker Images
Dirk Stenger stenger at lat-lon.de
Wed Feb 15 02:51:45 PST 2023
Thanks for all the help. Now, the build of ubuntu-full also works.
The reason that I am trying to build it is that I need a Debian GDAL Image.
Unfortunately, the command which is derived from the readme, leads to an
error:
~/git/gdal/docker$ BASE_IMAGE="debian:11"  ubuntu-full/build.sh --platform linux/amd64 --gdal v3.5.0
E: Package'libmysqlclient-dev'  has no installation candidate
The command'/bin/sh -c . /buildscripts/bh-set-envvars.sh     && apt-get update -y
   && DEBIAN_FRONTEND=noninteractive apt-get install -y --fix-missing
--no-install-recommends        libopenjp2-7-dev${APT_ARCH_SUFFIX}
libcairo2-dev${APT_ARCH_SUFFIX}        python3-dev${APT_ARCH_SUFFIX}
python3-numpy${APT_ARCH_SUFFIX} python3-setuptools${APT_ARCH_SUFFIX}
    libpng-dev${APT_ARCH_SUFFIX} libjpeg-dev${APT_ARCH_SUFFIX}
libgif-dev${APT_ARCH_SUFFIX} liblzma-dev${APT_ARCH_SUFFIX}
libgeos-dev${APT_ARCH_SUFFIX}        curl libxml2-dev${APT_ARCH_SUFFIX}
libexpat-dev${APT_ARCH_SUFFIX} libxerces-c-dev${APT_ARCH_SUFFIX}
  libnetcdf-dev${APT_ARCH_SUFFIX} libpoppler-dev${APT_ARCH_SUFFIX}
libpoppler-private-dev${APT_ARCH_SUFFIX}
  libspatialite-dev${APT_ARCH_SUFFIX}
librasterlite2-dev${APT_ARCH_SUFFIX} swig ant
libhdf4-alt-dev${APT_ARCH_SUFFIX} libhdf5-serial-dev${APT_ARCH_SUFFIX}
      libfreexl-dev${APT_ARCH_SUFFIX} unixodbc-dev${APT_ARCH_SUFFIX}
  mdbtools-dev${APT_ARCH_SUFFIX} libwebp-dev${APT_ARCH_SUFFIX}
  liblcms2-2 libpcre3-dev${APT_ARCH_SUFFIX}
libcrypto++-dev${APT_ARCH_SUFFIX} libfyba-dev${APT_ARCH_SUFFIX}
  libkml-dev${APT_ARCH_SUFFIX} libmysqlclient-dev${APT_ARCH_SUFFIX}
libogdi-dev${APT_ARCH_SUFFIX}        libcfitsio-dev${APT_ARCH_SUFFIX}
openjdk-"$JAVA_VERSION"-jdk${APT_ARCH_SUFFIX}
libzstd-dev${APT_ARCH_SUFFIX}        libpq-dev${APT_ARCH_SUFFIX}
libssl-dev${APT_ARCH_SUFFIX} libboost-dev${APT_ARCH_SUFFIX}
  autoconf automake bash-completion libarmadillo-dev${APT_ARCH_SUFFIX}
      libopenexr-dev${APT_ARCH_SUFFIX} libheif-dev${APT_ARCH_SUFFIX}
    libdeflate-dev${APT_ARCH_SUFFIX} libblosc-dev${APT_ARCH_SUFFIX}
liblz4-dev${APT_ARCH_SUFFIX} libbz2-dev${APT_ARCH_SUFFIX}
  libbrotli-dev${APT_ARCH_SUFFIX}
  libarchive-dev${APT_ARCH_SUFFIX}     && rm -rf /var/lib/apt/lists/*'  returned a non-zero code: 100
I assume that is the case because the Dockerfile references Ubuntu apt
repos?
Is there currently a way to build Debian based Images or do I have to
adjust the apt repos in the Dockerfile?
Kind regards,
Dirk
Am 14.02.23 um 23:53 schrieb Even Rouault:
> Le 14/02/2023 à 23:45, Dirk Stenger a écrit :
>> Thank you for the help.
>> Your proposed solution works for ubuntu-small.
>> However, when I am trying to build ubuntu-full, I get a new error:
> Did you "git pull" to get the latest state of the repository ? The
> error you get might come from the fact that you run a Docker build
> based on an outdated recipee which drags the new state of master, as
> the Docker build scripts do not use the GDAL sources of the working
> copy but from the latest master (yeah, quite unusual). There has been
> an update regarding pdfium beginning of December.
l a t / l o n  GmbH
Im Ellig 1                           53343 Wachtberg, Germany
phone ++49 +228 24 333 784
http://www.lat-lon.de                   http://www.deegree.org
lat/lon gesellschaft für raumbezogene informationssysteme mbH
Registergericht: Amtsgericht Bonn, HRB 13042
Geschäftsführer: Jens Fitzke und Torsten Friebe
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230215/a09142e0/attachment.htm>
