[gdal-dev] Segmentation fault while compiling
Even Rouault even.rouault at spatialys.com
Wed Feb 15 18:24:45 PST 2023
Le 16/02/2023 à 03:04, afernandez a écrit :
> The problem doesn't seem to be about having 2 copies of PROJ as I
> checked. I was able to compile v3.6.2 w/o this issue so it might be
> something in the master branch (maybe the python script that you mention).
Yes this is something recent in the master branch. I've filed an issue
about that https://github.com/OSGeo/gdal/issues/7252. Not sure how to
fix it at this point though
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230216/fda0a751/attachment.htm>
