[gdal-dev] Segmentation fault while compiling
afernandez afernandez at odyhpc.com
Thu Feb 16 04:37:11 PST 2023
v3.6.2. suffices for my purposes but it's obviously something to check. Thanks.
Even Rouault wrote:
Le 16/02/2023 à 03:04, afernandez a écrit :
The problem doesn't seem to be about having 2 copies of PROJ as I checked. I was able to compile v3.6.2 w/o this issue so it might be something in the master branch (maybe the python script that you mention).
Yes this is something recent in the master branch. I've filed an issue about that https://github.com/OSGeo/gdal/issues/7252 <https://github.com/OSGeo/gdal/issues/7252> . Not sure how to fix it at this point though
-- http://www.spatialys.com <http://www.spatialys.com> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230216/532d97d1/attachment.htm>
