[gdal-dev] filelock Python dependency now required for Python autotest [was Re: Segmentation fault while compiling]
Even Rouault even.rouault at spatialys.com
Thu Feb 16 09:47:28 PST 2023
The issue mentioned below is solved per
https://github.com/OSGeo/gdal/pull/7257. The solution requires the
"filelock" Python module to be installed. It has been added to the list
in autotest/requirements.txt
Le 16/02/2023 à 03:24, Even Rouault a écrit :
> Le 16/02/2023 à 03:04, afernandez a écrit :
>> The problem doesn't seem to be about having 2 copies of PROJ as I
>> checked. I was able to compile v3.6.2 w/o this issue so it might be
>> something in the master branch (maybe the python script that you
>> mention).
> Yes this is something recent in the master branch. I've filed an issue
> about that https://github.com/OSGeo/gdal/issues/7252. Not sure how to
> fix it at this point though
> http://www.spatialys.com
> My software is free, but my time generally not.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230216/ab706301/attachment-0001.htm>
