[gdal-dev] Is there any incompatibility between KEA and HDF5?
    afernandez
    afernandez at odyhpc.com
    Mon Feb 20 04:43:49 PST 2023
Hello,
I've been trying to build GDAL from source to add KEA support. The
configuration goes well and the compilation doesn't report any issue.
However, gdalinfo keeps outputting the following message:
~/gdal-3.4.3$ gdalinfo --version
GDAL 3.4.3, released 2022/04/22
HDF5-DIAG: Error detected in HDF5 (1.14.0) thread 0:
#000: H5P.c line 1486 in H5Pclose(): not a property list
major: Invalid arguments to routine
minor: Inappropriate type
PropList::~PropList - H5Pclose failed
I have tried several combinations varying GDAL versions (3.4.1, 3.4.3,
3.6.2), HDF5 (1.14 1.12) or whether the KEA lib is built with or without
GDAL support. However, it always ends up with the same problem. The error
message suggests an invalid argument, but I just don't know why this would
happen when KEA is loaded versus when it's not. [Info: the system is
running Ubuntu 22.04]
Thanks,
AFernandez
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230220/59d59a36/attachment.htm>
