[gdal-dev] More consistent use of pytest's parameterization in autotests
Sean Gillies sean.gillies at gmail.com
Mon Feb 20 07:42:45 PST 2023
Hi all,
I just saw a maintainer recommend to a contributor that the contributor
loop over test cases from within a test function and it prompted me to
speak up about a better practice: using pytest parameterization
https://docs.pytest.org/en/6.2.x/parametrize.html#pytest-mark-parametrize-parametrizing-test-functions
Using a loop, like at
https://github.com/OSGeo/gdal/blob/master/autotest/gcore/gdal_stats.py#L660,
can hide bugs and add friction to development. In that particular case,
there are 5 different fill values to be checked. If there are different
code paths for each of these values (a worst case scenario) and each has a
small bug, you will have to run the whole test suite 5 times to expose the
5 bugs one at a time. Additionally, these loops fix the order that the
checks are made, and bugs can hide in test order dependency. Ideally,
GDAL's tests run in random order.
In a nutshell, you hoist the loop and list out into a test function
decorator and then pytest discovers and runs all the separate cases. Pytest
doesn't stop on the first failure in the list unless you explicitly tell it
to do so.
# Original GDAL test code
def test_fill_value():
    for fill_val in [0, 1, 32767, 32768, 65535]:
        func(fill_val)
        assert something
# With pytest parameterization
@pytest.mark.parametrize("fill_val", [0, 1, 32767, 32768, 65535])
def test_fill_value(fill_val):
        func(fill_val)
        assert something
I'm not proposing rewrites of old tests, but I think it is worth adopting a
better practice for tests now and in the future.
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230220/06c925fd/attachment.htm>
