[gdal-dev] FileGDB_COMPILE fails during CMake
Scott public at postholer.com
Fri Feb 24 08:44:05 PST 2023
With gdal >= 3.6 OpenFileGDB is built in by default, no need for
external API.
On 2/24/23 08:37, Jon Morris wrote:
> Hi all,
> I’ve been upgrading our build script from autotools to CMake and I’ve
> almost got it working, except for FileGDB. I’ve added the cmake
> parameters  -DFileGDB_ROOT=/usr/local/FileGDB_API
> -DFileGDB_INCLUDE_DIR=/usr/local/FileGDB_API/include and the paths are
> correct. The earlier FileGDB install stage is the same as in
> https://github.com/OSGeo/gdal/blob/release/3.6/.github/workflows/ubuntu_20.04/build-deps.sh <https://github.com/OSGeo/gdal/blob/release/3.6/.github/workflows/ubuntu_20.04/build-deps.sh>.
> (I’ve also tried /usr/include for the include path with the same result).
> When I run CMake, I get the following lines in the log (irrelevant lines
> have been removed):
> -- Performing Test TEST_FileGDB_COMPILE
> -- Performing Test TEST_FileGDB_COMPILE - Failed
> -- Found FileGDB: /usr/local/FileGDB_API/lib/libFileGDBAPI.so
> -- Enabled drivers and features and found dependency packages
> -- The following features have been enabled:
> * ogr_FILEGDB, FileGDB
> -- The following OPTIONAL packages have been found:
> * FileGDB
>     Enable FileGDB (based on closed-source SDK) driver
> [ 82%] Building CXX object
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbDatasource.cpp.o
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbDriver.cpp.o
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbLayer.cpp.o
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbResultLayer.cpp.o
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbUtils.cpp.o
> [ 82%] Built target ogr_FileGDB
> [ 94%] Linking CXX shared library libgdal.so
> /opt/rh/devtoolset-10/root/usr/libexec/gcc/x86_64-redhat-linux/10/ld:
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbDatasource.cpp.o:
> in function FGdbDataSource::DeleteLayer(int)':
> FGdbDatasource.cpp:(.text+0x12b0): undefined reference to
> `FileGDBAPI::Geodatabase::Delete(std::basic_string<wchar_t,
> std::char_traits<wchar_t>, std::allocator<wchar_t> > const&,
> std::basic_string<wchar_t, std::char_traits<wchar_t>,
> std::allocator<wchar_t> > const&)'
> Many more undefined reference errors follow.
> Does anyone know what could be going wrong here and what else I can try
> to debug it? I’m all out of ideas.
> Many thanks,
> Jon
> e: ​	*Jon.Morris at jbarisk.com* <mailto:Jon.Morris at jbarisk.com>
> d:	+44 (0)1756 587229
> t: 	*+44 (0)1756 799919* <tel:+44%20(0)1756%20799919>
> *www.jbarisk.com* <http://www.jbarisk.com/>
> Facebook <https://www.facebook.com/TheFloodPeople>
> LinkedIn <https://www.linkedin.com/company/jba-risk-management/>
> Twitter <https://twitter.com/JBARisk>
> YouTube <https://www.youtube.com/channel/UC0iatom2jYbW96voW0rlpCw>
> All JBA Risk Management's email messages contain confidential
> information and are intended only for the individual(s) named. If you
> are not the named addressee you should not disseminate, distribute or
> copy this e-mail.
> Please notify the sender immediately by email if you have received this
> email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number
> 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North
> Yorkshire, BD23 3FD, England.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
