[gdal-dev] FileGDB_COMPILE fails during CMake
Jon Morris Jon.Morris at jbarisk.com
Mon Feb 27 00:37:05 PST 2023
Does that mean we should no longer attempt to use the FileGDB API? Our tool makes quite heavy use of FileGDB so we'd have to do something like this every time a user wants to use it:
if GDAL_VERSION >= (3, 6):
    driver = 'OpenFileGDB'
else:
    driver = 'FileGDB'
Jon
e: Jon.Morris at jbarisk.com
d:+44 (0)1756 587229
t: +44 (0)1756 799919
www.jbarisk.com
All JBA Risk Management's email messages contain confidential information and are intended only for the individual(s) named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system.
JBA Risk Management Limited is registered in England, company number 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North Yorkshire, BD23 3FD, England.
-----Original Message-----
From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Scott
Sent: 24 February 2023 16:44
To: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] FileGDB_COMPILE fails during CMake
CAUTION: This email originated from outside of JBA and contains one or more links. DO NOT click links unless you recognise the sender's email address and are absolutely certain that the content is safe.
See the Phishing page on IMS on SP for more information about how to spot and report suspicious messages.
With gdal >= 3.6 OpenFileGDB is built in by default, no need for external API.
On 2/24/23 08:37, Jon Morris wrote:
> Hi all,
> I’ve been upgrading our build script from autotools to CMake and I’ve
> almost got it working, except for FileGDB. I’ve added the cmake
> parameters  -DFileGDB_ROOT=/usr/local/FileGDB_API
> -DFileGDB_INCLUDE_DIR=/usr/local/FileGDB_API/include and the paths are
> correct. The earlier FileGDB install stage is the same as in
> https://github.com/OSGeo/gdal/blob/release/3.6/.github/workflows/ubuntu_20.04/build-deps.sh <https://github.com/OSGeo/gdal/blob/release/3.6/.github/workflows/ubuntu_20.04/build-deps.sh>.
> (I’ve also tried /usr/include for the include path with the same result).
> When I run CMake, I get the following lines in the log (irrelevant
> lines have been removed):
> -- Performing Test TEST_FileGDB_COMPILE
> -- Performing Test TEST_FileGDB_COMPILE - Failed
> -- Found FileGDB: /usr/local/FileGDB_API/lib/libFileGDBAPI.so
> -- Enabled drivers and features and found dependency packages
> -- The following features have been enabled:
> * ogr_FILEGDB, FileGDB
> -- The following OPTIONAL packages have been found:
> * FileGDB
>     Enable FileGDB (based on closed-source SDK) driver
> [ 82%] Building CXX object
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbDatasource.cpp.
> o
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbDriver.cpp.o
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbLayer.cpp.o
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbResultLayer.cpp
> .o
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbUtils.cpp.o
> [ 82%] Built target ogr_FileGDB
> [ 94%] Linking CXX shared library libgdal.so
> /opt/rh/devtoolset-10/root/usr/libexec/gcc/x86_64-redhat-linux/10/ld:
> ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbDatasource.cpp.o:
> in function FGdbDataSource::DeleteLayer(int)':
> FGdbDatasource.cpp:(.text+0x12b0): undefined reference to
> `FileGDBAPI::Geodatabase::Delete(std::basic_string<wchar_t,
> std::char_traits<wchar_t>, std::allocator<wchar_t> > const&,
> std::basic_string<wchar_t, std::char_traits<wchar_t>,
> std::allocator<wchar_t> > const&)'
> Many more undefined reference errors follow.
> Does anyone know what could be going wrong here and what else I can
> try to debug it? I’m all out of ideas.
> Many thanks,
> Jon
> e: ​  *Jon.Morris at jbarisk.com* <mailto:Jon.Morris at jbarisk.com>
> d:    +44 (0)1756 587229
> t:    *+44 (0)1756 799919* <tel:+44%20(0)1756%20799919>
> *www.jbarisk.com* <http://www.jbarisk.com/>
> Facebook <https://www.facebook.com/TheFloodPeople>
> LinkedIn <https://www.linkedin.com/company/jba-risk-management/>
> Twitter <https://twitter.com/JBARisk>
> YouTube <https://www.youtube.com/channel/UC0iatom2jYbW96voW0rlpCw>
> copy this e-mail.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230227/6fe01bfc/attachment-0001.htm>
Type: image/png
Desc: image921419.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230227/6fe01bfc/attachment-0005.png>
Type: image/png
Desc: image602514.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230227/6fe01bfc/attachment-0006.png>
Type: image/png
Desc: image354811.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230227/6fe01bfc/attachment-0007.png>
Type: image/png
Desc: image392918.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230227/6fe01bfc/attachment-0008.png>
Type: image/png
Desc: image898252.png
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230227/6fe01bfc/attachment-0009.png>
