[gdal-dev] FileGDB_COMPILE fails during CMake
Scott public at postholer.com
Mon Feb 27 08:02:35 PST 2023
3.6 has read, write, update and create abilities using the builtin
OpenFIleGDB. Building from source on linux I don't specify anything.
On 2/27/23 00:37, Jon Morris wrote:
> Does that mean we should no longer attempt to use the FileGDB API? Our
> tool makes quite heavy use of FileGDB so we'd have to do something like
> this every time a user wants to use it:
> if GDAL_VERSION >= (3, 6):
> driver = 'OpenFileGDB'
> else:
> driver = 'FileGDB'
> Jon
> e: ​	*Jon.Morris at jbarisk.com* <mailto:Jon.Morris at jbarisk.com>
> d:	+44 (0)1756 587229
> t: 	*+44 (0)1756 799919* <tel:+44%20(0)1756%20799919>
> *www.jbarisk.com* <http://www.jbarisk.com/>
> Facebook <https://www.facebook.com/TheFloodPeople>
> LinkedIn <https://www.linkedin.com/company/jba-risk-management/>
> Twitter <https://twitter.com/JBARisk>
> YouTube <https://www.youtube.com/channel/UC0iatom2jYbW96voW0rlpCw>
> All JBA Risk Management's email messages contain confidential
> information and are intended only for the individual(s) named. If you
> are not the named addressee you should not disseminate, distribute or
> copy this e-mail.
> Please notify the sender immediately by email if you have received this
> email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number
> 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North
> Yorkshire, BD23 3FD, England.
> -----Original Message-----
> From: gdal-dev <gdal-dev-bounces at lists.osgeo.org> On Behalf Of Scott
> Sent: 24 February 2023 16:44
> To: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] FileGDB_COMPILE fails during CMake
> CAUTION: This email originated from outside of JBA and contains one or
> more links. DO NOT click links unless you recognise the sender's email
> address and are absolutely certain that the content is safe.
> See the Phishing page on IMS on SP for more information about how to
> spot and report suspicious messages.
> With gdal >= 3.6 OpenFileGDB is built in by default, no need for
> external API.
> On 2/24/23 08:37, Jon Morris wrote:
>  > Hi all,
>  > I’ve been upgrading our build script from autotools to CMake and I’ve
>  > almost got it working, except for FileGDB. I’ve added the cmake
>  > parameters -DFileGDB_ROOT=/usr/local/FileGDB_API
>  > -DFileGDB_INCLUDE_DIR=/usr/local/FileGDB_API/include and the paths are
>  > correct. The earlier FileGDB install stage is the same as in
> https://github.com/OSGeo/gdal/blob/release/3.6/.github/workflows/ubuntu_20.04/build-deps.sh <https://github.com/OSGeo/gdal/blob/release/3.6/.github/workflows/ubuntu_20.04/build-deps.sh>.
>  > (I’ve also tried /usr/include for the include path with the same result).
>  > When I run CMake, I get the following lines in the log (irrelevant
>  > lines have been removed):
>  > -- Performing Test TEST_FileGDB_COMPILE
>  > -- Performing Test TEST_FileGDB_COMPILE - Failed
>  > -- Found FileGDB: /usr/local/FileGDB_API/lib/libFileGDBAPI.so
>  > -- Enabled drivers and features and found dependency packages
>  > -- The following features have been enabled:
>  > * ogr_FILEGDB, FileGDB
>  > -- The following OPTIONAL packages have been found:
>  > * FileGDB
>  > Enable FileGDB (based on closed-source SDK) driver
>  > [ 82%] Building CXX object
>  > ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbDatasource.cpp.
>  > o
>  > ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbDriver.cpp.o
>  > ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbLayer.cpp.o
>  > ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbResultLayer.cpp
>  > .o
>  > ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbUtils.cpp.o
>  > [ 82%] Built target ogr_FileGDB
>  > [ 94%] Linking CXX shared library libgdal.so
>  > /opt/rh/devtoolset-10/root/usr/libexec/gcc/x86_64-redhat-linux/10/ld:
>  > ogr/ogrsf_frmts/filegdb/CMakeFiles/ogr_FileGDB.dir/FGdbDatasource.cpp.o:
>  > in function FGdbDataSource::DeleteLayer(int)':
>  > FGdbDatasource.cpp:(.text+0x12b0): undefined reference to
>  > `FileGDBAPI::Geodatabase::Delete(std::basic_string<wchar_t,
>  > std::char_traits<wchar_t>, std::allocator<wchar_t> > const&,
>  > std::basic_string<wchar_t, std::char_traits<wchar_t>,
>  > std::allocator<wchar_t> > const&)'
>  > Many more undefined reference errors follow.
>  > Does anyone know what could be going wrong here and what else I can
>  > try to debug it? I’m all out of ideas.
>  > Many thanks,
>  > Jon
>  > copy this e-mail.
>  > this email by mistake and delete this email from your system.
>  > _______________________________________________
>  > gdal-dev mailing list
>  > https://lists.osgeo.org/mailman/listinfo/gdal-dev
