[gdal-dev] create ntif file with NITF_IGEOLO field set
Amadeus WM amadeus84 at verizon.net
Fri Feb 24 21:44:10 PST 2023
Hello everyone,
I'm new to GDAL and I'm trying to figure out how to create a NITF file
given the raw data, that also has the NITF_IGEOLO field set. With a
little help from chatGPT I came up with the c++ program below (it has
to be in c++). It writes the file, but it does not contain the
NITF_IGEOLO field. I do set it in the code with
GDALDataset::SetMetadataItem() and it does appear to be set in the
metadata. It just does not show up in the output file, when I inspect
it with gdalinfo -mdd all.
Can anyone help please? Thank you!
Here is the code
// g++ -g -Wall -o nitf nitf.cpp -lgdal
#include <gdal/gdal.h>
#include <gdal/gdal_priv.h>
#include <iostream>
#include <cstdlib>
using namespace std;
int main(int argc, char* argv[])
    const size_t rows=512, cols=512;
    uint16_t data[rows*cols];
    GDALAllRegister();
    GDALDriver* driver=GetGDALDriverManager()->GetDriverByName("NITF");
    GDALDataset* dataset=driver->Create("out.ntf", rows, cols, 1, GDT_UInt16, 0);
    // We want to add and set NITF_IGEOLO
    dataset->SetMetadataItem("NITF_IGEOLO", "1234");
    // It does get set in the metadata
    auto md=dataset->GetMetadata();
    for (size_t i=0; md[i]!=nullptr; i++)
	cout << md[i] << endl;
    // but does not get written to file
    GDALRasterBand* band=dataset->GetRasterBand(1);
    if (band->RasterIO(GF_Write, 0, 0, rows, cols, (void*)data, rows, cols, GDT_UInt16, 0, 0)==CE_Failure)
	throw "Error";
    GDALClose((GDALDatasetH)dataset);
    return 0;
