[gdal-dev] sozip and tile index
Even Rouault even.rouault at spatialys.com
Sun Jul 2 06:20:22 PDT 2023
ogrtindex can index any OGR supported file including through the /vsi
virtual file systems such as /vsizip/ , /vsicurl/ or combinations of those
Even
Le 27/06/2023 à 13:00, Andrew Terry a écrit :
> Hi,
> Is it possible to include a virtual file system file in a ogrtindex
> (or alternative?) vector file index?
> My ideal use case is to include sozip enabled or just plain zip files.
> At the moment the files are one shp per zip which makes it easy to
> swap out changed data.
> Thanks
> Andy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230702/d6015bf3/attachment.htm>
