[gdal-dev] sozip and tile index
Andrew Terry andrew.terry at centremaps.co.uk
Mon Jul 3 01:52:33 PDT 2023
Thanks Even, that’s great I’ll try again using those!
Sent: Sunday, July 2, 2023 2:20 PM
To: Andrew Terry <andrew.terry at centremaps.co.uk>; gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] sozip and tile index
ogrtindex can index any OGR supported file including through the /vsi virtual file systems such as /vsizip/ , /vsicurl/ or combinations of those
Even
Le 27/06/2023 à 13:00, Andrew Terry a écrit :
Is it possible to include a virtual file system file in a ogrtindex (or alternative?) vector file index?
My ideal use case is to include sozip enabled or just plain zip files.
At the moment the files are one shp per zip which makes it easy to swap out changed data.
Thanks
Andy
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20230703/bb990c0e/attachment.htm>
