[gdal-dev] ogr2ogr sqlite dialect and fgb format
Even Rouault even.rouault at spatialys.com
Mon Jul 3 02:10:59 PDT 2023
Hi Patrick,
blocking error fixed per https://github.com/OSGeo/gdal/pull/8040
and the one related to esriFieldTypeDate in
https://github.com/OSGeo/gdal/pull/8039
Even
Le 28/06/2023 à 17:18, Patrick Young a écrit :
> Hi,
> I'm playing around with the gdb dataset
> https://data.cityofnewyork.us/Transportation/NYC-Planimetrics/wt4d-p43d
> and getting errors starting with gdal 3.5 when I try to use the sqlite
> dialect:
> ogr2ogr -f GeoJSONSeq -sql "select shape from roadbed where source_id
> = 13350003311" -dialect sqlite /vsistdout/
> NYC_DoITT_Planimetric_OpenData.gdb.zip
> ERROR 6: Unsupported field type for range domain: esriFieldTypeDate
> ERROR 1: Cannot create virtual table for layer 'roadbed' : CREATE
> VIRTUAL: invalid SQL statement : CREATE TABLE "roadbed"("SOURCE_ID"
> FLOAT,"FEATURE_CODE"
> INTEGER_INT16_BEGIN_DOMAIN_NAME_64526F6164626564_END_DOMAIN_NAME,"SUB_FEATURE_CODE"
> INTEGER,"STATUS"
> VARCHAR(16)_BEGIN_DOMAIN_NAME_645374617475735F31_END_DOMAIN_NAME,"SHAPE_Length"
> FLOAT,"SHAPE_Area" FLOAT,OGR_STYLE VARCHAR HIDDEN,"SHAPE"
> BLOB_MULTIPOLYGON_XY_2263, OGR_NATIVE_DATA VARCHAR,
> OGR_NATIVE_MEDIA_TYPE VARCHAR)
> ERROR 1: In ExecuteSQL(): sqlite3_prepare_v2(select shape from roadbed
> where source_id = 13350003311):
>   no such table: roadbed
> This command works in GDAL 3.4 (and also works with the ogr sql
> dialect); I was wanting to use the sqlite dialect so that i can use
> CASE statements.  Is this a bug or expected?
> Thanks,
> Patrick
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
